Asus tuf gaming vg259qm 60hz input lag settings?
Posted: 21 Dec 2024, 16:28
by MIrwali
Hi i bought asus vg259qm for ps5 main game ea fc (fifa)25 which is 60hz and i feel like input deley is high when i play cod warzone on 120hz there is good gameplay plus less input deley so which setting should i do for ps5 to get low input deley and good gameplay as i do only ea fc fut online Thanx
Re: Asus tuf gaming vg259qm 60hz input lag settings?
Posted: 21 Dec 2024, 22:46
by joseph_from_pilsen
Isnt it bad idea to buy monitor which has low input lag only at highest refresh settings?
Posted: 22 Dec 2024, 08:38
by RealNC
MIrwali wrote: ↑
21 Dec 2024, 16:28
It's not fixable. This monitor has abnormally high input lag at 60Hz. See:
https://www.rtings.com/monitor/reviews/ ... #test_1435
120Hz: 4.8 ms
60Hz: 35.0 ms
Input lag is more than 7 times higher when going from 120 to 60. This is simply not a good monitor for PS5, or any gaming in general that needs 60Hz output.
Posted: 23 Dec 2024, 12:11
by MIrwali
RealNC wrote: ↑
22 Dec 2024, 08:38
MIrwali wrote: ↑
21 Dec 2024, 16:28
120Hz: 4.8 ms
60Hz: 35.0 ms
it is working very well on ps5 cod warzone if ea fc become 120hz in future then it will work good and smooth
Posted: 23 Dec 2024, 12:21
by MIrwali
Which monitor should you recommend for ea fc 25 and also for future high fps games to get less input deley i will sell asus and get that model then
Posted: 23 Dec 2024, 14:13
by RealNC
MIrwali wrote: ↑
23 Dec 2024, 12:21
I don't know. But whatever you pick, check on rtings.com to make sure it doesn't have excessive lag at 60Hz. Not all PS5 games support 120Hz.
