Hey Blur Busters,
Recently i dived into custom OS, debloated, normal windows or sort of stuff until i fixed my problem and my game works perfectly now except when i start the stream on Public mode on Youtube.
So long story short i've been trying to fix this issue for past few months and was wondering what can cause it, today i tested my game (CS2) with anticheat and OBS open with game capture and everything worked really smooth i've put my live streaming on Private on youtube so my subs dont get notified and the game worked perfectly but when i stopped that stream and decided its time to stream, thinking everything was done with the problems i was having, i put my stream on public restarted it and the feeling came back it was again shit (pardon my french), anyone maybe had similar issues with youtube or smthg?
Thanks in advance.
Floaty mouse feeling, weird game behavior when streaming
Rema
vroktylF
Re: Floaty mouse feeling, weird game behavior when streaming
Maybe this is the cause and High DPI scaling override is the solution? A mismatch between input and output scaling.
Text is copied from Microsoft Learn. (not possible to paste the link here it seems
Mouse input in some games is incorrectly scaled on high-DPI devices
Article
12/26/2023
3 contributors
In this article
Introduction
Workaround
This article describes how to work around an issue in which mouse input in some games is incorrectly scaled on high-DPI devices.
Applies to: Windows 8.1
Original KB number: 2907016
Introduction
Windows 8.1 supports bitmap scaling of desktop application content for applications that don't natively support high-DPI displays. It also scales mouse, pen, and touch input that is sent to those applications. Scaling both input and output guarantees a consistent experience for the application user.
However, there are two scenarios in which scaling can be mismatched:
Games that run in full-screen mode and bypass the output scaling of Windows (only input is scaled)
Games that use "raw mouse input" in windowed mode and bypass the input scaling of Windows (only output is scaled)
Most Windows desktop applications don't use full-screen mode or raw input. However, games frequently use one or both configurations. Windows detects many full-screen games and exempts them from both input and output high-DPI scaling on successive starts. But this detection fails in some games and upgrade scenarios. In these cases, you may experience mouse input that is either consistently larger or consistently smaller than what is reflected on the screen. The effect can be seen either in the position of the pointer or the location at which you can interact with on-screen content.
Workaround
We recommend that you manually configure games to be exempt from output and input high-DPI scaling. This should be done only for specific applications. This is because a change in the global desktop DPI scaling settings affects other desktop applications and may cause content to be displayed too small to be usable.
To make these configurations, locate the game's executable binary, and then change the compatibility properties of that file. To do this, follow these steps:
Locate the game's executable binary. You can usually search for the file by using Windows 8.1 search, as follows:
On the Start screen, type the name of the game application.
Right-click or press and hold the application's icon, and then select Open file location.A folder that contains the start menu shortcut for the application will open.
Change the compatibility properties, as follows:
Right-click or press and hold the file explorer icon for the application, and then select Properties.
On the Compatibility tab, select the Disable display scaling on high DPI settings check box.
Tap or click Apply, and then tap or click OK.
Additional troubleshooting tips
For some games, the shortcut starts a "launcher" application that then starts the game. You may have to locate the actual game application and then apply this compatibility change to it.
Some applications provide compatibility options within the application instead of using the application's Properties window. If this window doesn't have a Compatibility tab, determine whether the options within the application include the ability to disable high-DPI scaling.
Rema
Better something than nothing, thanks bro ill try that when i start the stream next time and see if it works as it should.vroktylF wrote: ↑17 Jan 2025, 03:05Maybe this is the cause and High DPI scaling override is the solution? A mismatch between input and output scaling.
Text is copied from Microsoft Learn. (not possible to paste the link here it seems)
Article
12/26/2023
3 contributors
In this article
Introduction
Workaround
Introduction
Workaround
