Radiofrequency and EMI/RFI Input Lag Fix
Mighty
Post by Mighty » 12 Feb 2025, 16:13
So i found a recent EMI/RFI Fix on Youtube from some Russlan guy who told me in his video that Radiofrequency is the source of Input Lag most of us suffer. It made me think about grounding and how Radioantennas work and as i talked with ChatGPT about this stuff i asked it if you can invert the function of an antenna not to take incoming frequencys as a source but more like the reversal and give the EMI/RFI signals from your components and outsource it to the world pretty much like a signal source... long story short ChatGPT confirmed that it could work so i tried it out and i can tell proudly that in my case it worked! I have a huge input lag reduction on my overall system and played some matches in cs2. Spray is far more easier to control i have a preciser mouse, picture of my monitor is more fluid and i also have more reaction time. AND better hitreg.
I will post you guys some pictures how i Wired the grounding from my PC Case to the Outside of my window BUT FIRST!!!
HUGE DISCLAIMER!!!!!!!
AS I AM A CERTIFIED ELECTRICIAN I KNOW HOW DANGEROUS POWER AND VOLTAGE CAN BE AND IF YOU CONNECT A WIRE TO YOUR PC AND LET IT HANG OUTSIDE OF YOUR WINDOW IT CAN DRAW ATTENTION OF A LIGHTNINGSTRIKE THERFORE IT IS VERY DANGEROUS!!!!
ONLY TRY THIS OUT IF YOU ARE AN ELECTRICIAN ASWELL 18+ YEARS OLD OR YOU KNOW WHAT THE FUCK YOU ARE DOING! NEVER EVER TRY THIS FIX ON A THUNDERSTORM AS IT COULD POTENTIAL HARM YOU OR WORSE!!!
IF YOU ARE UNDER 18 and DONT KNOW THE DANGERS OF ELECTRICITY DONT DO THIS!!!!!
here are the pics, note that there is no current on the wires off the picture its pure Grounding!!!
https://ibb.co/8npR9bgH
https://ibb.co/Dg877TsQ
https://ibb.co/2YKGmj8n
EDIT: after 3 days of testing i can confirm that it is the best fix i have found so far in like 5 years of searching :)
kyube
Re: Radiofrequency and EMI/RFI Input Lag Fix
Post by kyube » 12 Feb 2025, 17:07
Mighty wrote: ↑
12 Feb 2025, 16:13
Mighty wrote: ↑
12 Feb 2025, 16:13
Mighty wrote: ↑
12 Feb 2025, 16:13
So which one is it?
Are you a electrician or a believer in ChatGPT who got scammed by a random youtube video and now want to perpetuate that scam to this forum, like 95% of dwellers here?
No, you haven't achieved "PURE GROUNDING" with that setup.
Look for trained individuals, such as electric engineers with a degree, to guide you further in your quest.
No, you're very likely not suffering from any EMI issues, you've just invested in bad HW and haven't optimized your SW stack properly.
Stop spreading FUD.
Mighty
Post by Mighty » 12 Feb 2025, 17:26
if you consider an i9 and 3080ti ddr5 ram bad hardware ok... also i am an electrician but i am sure what ever you are working you know 100% of the stuff you do in your work from your mind and you never had to ask anyone about anything at all :lol:
anyways i am just giving information if you dont want to try it you dont have to ;)
and what fucked up answer is "ArE YoU a BeLiEvEr iN ChatGPT" AI knows its stuff and i am an Electrician in Industry witch CNC Machines not with radio stuff so appologies for asking someone about its opinion atleast i know how to execute and test stuff rather than blaming someone about stuff you dont know shit about...
LeGiT
Post by LeGiT » 15 Feb 2025, 14:29
tried this about 2 years ago and it comes back after a few days.
