macbook m3 pro external screen
dpaq
Post by dpaq » 18 Feb 2025, 13:50
Hello
I am struggling to find an external screen that will look the same as the macbook crisp resolution.
I bought a curved 32 inch from Dell S3221QSA but its not great, I have tinkered with it enough so that it acceptable but its nothing like the laptop screen (the whites are yellowish and the text is not super sharp). I am connecting via supplied HDMI cable directly from the MAC. I downloaded BetterDisplay software and that helped a bit.
I have since found out that Dell do not even support macs so that was not the smartest purchase, I will send it back.
I do like the curve though so would like to be able to get a screen like that.
Thanks!
