Something that helped me a lot lately
mackalren
Post by mackalren » 16 Mar 2025, 13:53
So I did tremendous amount of different tweeks, manipulations etc.
Running fresh r7 9800x3d + 6000cl30 + asus rox x870e hero + 3060 ti from my old intel build
Monitor : benq xl2566k
Currently I'm on almost non-tweeked kirbyOS, latest non-beta version.
I've always had visibility issues in cs2 when I move my mouse, basically playing, I struggled to notice enemy on my screen due to very unsmooth gameplay on display. I also have hit-reg and peek issues.
So I've never did but yesterday tried to set my nvidia display settings to this:
Screenshot 2025-03-16 214200.png (25.78 KiB) Viewed 3068 times
Before I used to be on GPU. Difference is great, the image is clearer, better quality and smoother.
It is not placebo, since I instantly I asked a friend to try it, who doesn't know anything about the topic of input lag and so on. He was shocked by the difference. He have XL2566X+
After that today I tried something I found here on the forum:
viewtopic.php?f=10&t=14343#p113053
Computer Configuration, Administrative Templates, System:
Display highly detailed status messages - Disabled
Computer Configuration, Administrative Templates, Windows Components, Event Logging:
Enable Protected Event Logging - Disabled
Computer Configuration, Administrative Templates, Windows Components, Event Viewer:
Events.asp program - Disabled
User Config, Admin Templates, System, Scripts:
Run legacy logon scripts hidden - Enabled
Run logon scripts synchronously - Disabled
Run Windows PowerShell scripts first at user logon, logoff - Enabled
User Config, Admin Templates, System:
Prevent Access to the command prompt - Enabled ; Disable the command prompt script processing also - Yes
Prevent Access to registry editing tools - Enabled ; Disable regedit from running silently - Yes
It's gave me more responsiveness and now I feel game much better, still not ideal but huge jump from what I had lately.
Hyote
Re: Something that helped me a lot lately
Post by Hyote » 16 Mar 2025, 19:04
mackalren wrote: ↑
16 Mar 2025, 13:53
Even though you set it to scale on Display, this still uses GPU scaling.
Also, KirbyOS is okay but MouseDataQueueSize and KeyboardDataQueueSize are set to 200, meaning there is some added delay compared to the Windows default value (100) and the usual tweaked numbers (16-25) are also much better. I think you got into the territory where added lag causes everything to feel smoother but I can almost guarantee it won't last long.
mackalren
Post by mackalren » 16 Mar 2025, 19:30
Hyote wrote: ↑
16 Mar 2025, 19:04
mackalren wrote: ↑
16 Mar 2025, 13:53
Nah, it's not like placebo or 50% placebo, it's 100% different image on my screen with display scaling instead of gpu in nvidia. 1280x960 feels like 1440x1080 in terms of image quality.
