old computer:
CPU: Intel Core i5-10400 2.9 GHz 6-Core Processor (Purchased For $159.00)
CPU Cooler: Cooler Master Hyper 212 EVO V2 62 CFM CPU Cooler (Purchased For $40.00)
Motherboard: Gigabyte B460M AORUS PRO Micro ATX LGA1200 Motherboard (Purchased For $99.00)
Memory: Silicon Power SP016GXLZU320BDAAD 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory (Purchased For $64.79)
Storage: Silicon Power A55 256 GB 2.5" Solid State Drive (Purchased For $27.99)
Video Card: EVGA XC GAMING GeForce RTX 3060 Ti 8 GB Video Card (Purchased For $0.00)
Case: Fractal Design Meshify C ATX Mid Tower Case (Purchased For $0.00)
Power Supply: EVGA 600 W1 600 W 80+ Certified ATX Power Supply (Purchased For $0.00)
New Computer:
CPU: Intel Core i5-13400F 2.5 GHz 10-Core Processor ($134.94 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler ($34.90 @ Amazon)
Motherboard: Gigabyte H610I Mini ITX LGA1700 Motherboard ($129.99 @ Amazon)
Memory: TEAMGROUP Elite 32 GB (2 x 16 GB) DDR5-5600 CL46 Memory ($69.98 @ Amazon)
Storage: Silicon Power A55 1 TB M.2-2280 SATA Solid State Drive ($48.97 @ Amazon)
Video Card: Gigabyte GAMING OC Radeon RX 9070 16 GB Video Card ($689.99 @ B&H)
Power Supply: Thermaltake Smart BM3 850 W 80+ Bronze Certified Semi-modular ATX Power Supply ($99.99 @ Amazon)
Attached is a screenshot of my latencymon.
Essentially, it seems like my mouse skips pixels or drops input very consistently. Its very fast, and when playing games, it looks as though the game is stuttering, but when i use a controller, its perfectly smooth. My frametimes are smooth, i have no issues running the titles im trying to play, and this issue happens across every game that uses the mouse i've been able to play so far, which are helldivers 2, overwatch, minecraft, and repo, so a mixture of games that use the input from windows, and one that uses raw input. This happens on both computers, which seems absolutely bizarre to me.
the steps to troubleshoot i've done so far are:
Clean boot into windows
Used 3 different mice on different mousepads
Disconnecting everything from my computer except the mouse
using different usb ports
reinstalling different versions of windows on different drives
and probably more to be honest.
I spent a lot of money on all this and the issue still isnt fixed. its so frustrating and demoralizing. I dont really know what to do from here. I'm pretty tech savy and have a degree in computer science, and im at a loss. Anybody have any ideas?
New Computer, New OS, new everything - same stuttering mouse input.
labree0
- Slender
Re: New Computer, New OS, new everything - same stuttering mouse input.
do you has old hardware?
FYNE
How much DPI are you using? Go higher and see if it makes any difference
also if nothing seems to help: you could try a different household (ideal case which got recently build to guarantee new wiring) I was reading this a lot in this forum, that ppl have problems with "bad energy"
daviddave1
try https://youtu.be/10ujLjMFxOA?si=kdVPqkHFCZLIiChW no guarantee it will work.labree0 wrote: ↑20 Mar 2025, 12:52old computer:
New Computer:
also configure usb as in https://youtu.be/IyzFodkeHBQ?si=Fm0SNDBuIqvnpi2A again no single guarantee it will work.
| Now: XG27AQNGV
