Mouse Input Lag and weird feel when peripherals like mouse and keyboard are connected to usb port while booting up.
A fix i have found is
The normal motherboard usb ports cause me input lag which is insanely noticeable so what i did was My monitor has a usb hub i connect the mouse usb receiver to the usb and plug the usb a of the (usb a to usb b cable) to the motherboard usb 3.0 after my windows is loaded fully. But everytime i restart i have to remove the usb receiver from the monitor usb hub and the usb b to a cable from motherboard basically repeating the whole process. I have no clue whats the issue. Does someone have a fix ? Is my motherboard faulty? I dont know if sending it to RMA would even fix this problem since i dont know whats causing this issue. Either Power problem or Motherboard or something else i have no clue
Mouse Input Lag/Delay on Boot etc
basitbatin
Return to “Input Lag / Display Lag / Network Lag”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — BFI / ULMB / ELMB / DyAc / framegen / LSS / etc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory: Display Science Section
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
