ICC Profiles question
Spartan
Post by Spartan » 30 Mar 2025, 13:17
From what I've learned is you don't wanna use an ICC profile not specifically made for your monitor, ie: you find a monitor review of the same model that you own which contains an ICC profile, even though it's the same model, no panel is the same so it's not recommended.
However, we often see manufacturers include an ICC profile when you download the drivers for a monitor yet everyone seems to be using them.
I am confused, thoughts?
ASUS ROG Strix SCAR 16 G635LX | Intel Core Ultra 9 275HX | SK Hynix 64GB DDR5-5600MHz RAM | GeForce RTX 5090 | BOE NE160QDM-NM8 16" WQXGA 240Hz Mini-LED Display + AOC Agon PRO AG274QZM QHD Mini-LED Monitor | 2x WD_BLACK SN850X 8TB SSDs (RAID 0) | Intel Wi-Fi 7 BE200 WLAN | Windows 11 Pro
Re: ICC Profiles question
Post by RealNC » 30 Mar 2025, 15:33
ICC profiles from monitor vendors don't include full calibration data. They're usually very small because of that. They only include things like color primaries, which define the color gamut and gamma of the display. These work fine across all units.
If you download a full calibration ICC profile instead, it's gonna be much larger in file size and contains much more data. That data is used to alter colors at various luminance levels, and that part is what can differ a lot between units. I believe screen uniformity affects it as well, and since screen uniformity is one the most random things between units, color calibration data will also be quite different.
Spartan
Post by Spartan » 30 Mar 2025, 19:15
Got it, thanks a lot for this detailed answer.
