1) Have 780p mag monitor for the past five years.
2) Plays competitively in a team-play focused RTS scrolling kind of game (The game called DotA you used to play it on WC3 engine Now it evolved into Source engine future to move into Souse 2 engine) here is a gameplay vid :http://www.youtube.com/watch?v=ZClNGH-e ... x8Sv_6WERg you can run it at 120FPS.
3)Not playing competitively in any FP shooter game.
4)Look forward to play SOM with my new pc and monitor purchase
5)All my life I had shitty PC's
Now I cant even play because the poor laptop cant handle it anymore and crashes.
I just finished serving in the army and I want to buy my first REAL PC and a 1080p monitor I have the budget to afford a non g-sync more then 60hz monitor and a high end gaming PC (I want to buy a single 24" monitor btw) I can extend my budget if the new XL2420G is worth the spending for my uses.
Now I want you guys to consider all the info above and advice me about whether I should go for a 144hz monitor like the benq XL24020z
and buy a PC that can give me more then 60 FPS performance at 1080p or whether should I buy a good 1080p IPS monitor and save a lot of bucks on both the PC and the monitor ?
What should I go for guys ?
Describe me your first experience with the transition into more then 60hz ?
What games do you play ?
When do you recommend 60FPS and when will you recommend 120FPS ?
Colors ?
modes ?
Pros & Cons ?
Any DotA players here ?
(Don't misunderstand me I obtained plenty of technical information and I understand this technology I don't want technical information
I want your personal opinions and experiences )
