Reflex + FPS cap
Reflex + FPS cap
Is it possible to match my fps nvcp fps cap to the same as reflex? For example 158 fps on a 165hz monitor. I don't want to use ULLM to cap it since I have issues with it, but some games doesn't have reflex and I want to cap it, but 162 close to 165 so I would like to cap it to 158. What happens when reflex is active while my fps cap is on too? Reflex wont be as effective as it should? I don't want to change settings on every game I play, I just want to set it and forget about it.
Re: Reflex + FPS cap
From my limited experience I'd suggest you cap it to 162 like you suggested.
That's low enough where G-sync will work as intended for non-reflex titles and it shouldn't interfer with Reflex as that caps it lower.
Any particular reason you want to match them exactly?
