Hello,
Like the title says, I am considering 2 options for CS2. I am at a competitive level where I often participate in tournaments and I would like a slight upgrade as I would prefer a 25" monitor.
I found a used AW2523HF for £130, and I started debating whether to get it or not. The only issue holding me back is during online tournaments, my pc usually gets a 250-320fps at 1720x1440, so im worried that it wont be enough for 360hz @ 1280x960, so I will most likely have to cap it to a slightly smaller refresh rate such as 240hz, 280hz or 300hz.
However I would also try to consider a 240hz TN with DYAC or some other BFI technology like ELMB or ULMB.
I hardly know what im talking about. I am confident I can run a stable 240hz. I am looking for a cpu upgrade within the next year, for now I would prefer to keep my pc specs as is. Im on an AMD cpu so I cant run any of the NVIDIA technology (like ULMB2 I believe is nvidia exclusive from what someone told me)
I want something with good motion clarity, something ideal for a fast paced competitive fps. I also want to use this monitor OCCASIONALLY for studying/work, however if this monitor wont serve that purpose I have a laptop that will do the job instead.
Or I can also consider a fast ips 240hz, however I cant find any that really suit my needs.
my needs are: Fast motion clarity, 240hz or higher (ideally around 240-320hz), <=1ms response time, 1080p, 24 or 25 inch.
Like I said I have 0 clue what im saying, if im even talking about the right thing. Realistically I want the best thing I can get. No more than £300. Im located in the UK. Second hand is perfectly fine for me, brand new is also no issue.
Many thanks,
please correct me if anything im saying is wrong.
Monitor recommendations for cs2? 360hz IPS vs 240hz TN + DYAC?
alexcs2
