Alienware AW2724HF problem
lolas
Post by lolas » 15 Jun 2025, 14:36
Hi guys im newbie on these things so bear with me. So basically i just got a Alienware AW2724HF 360hz 0.5ms Fast IPS 27' gaming monitor im using it for 2weeks now. Previously i was playing with EVNIA 180HZ monitor 0.5ms normal IPS. I tought it will be an upgrade, but i was wrong and i dont know where the problem is. Basically whenever i play with this Alienware monitor and load up some cs2 it feels like shots are just simply not registering+stuttering feeling whereas when i connect the other Evnia monitor everything comes back to normal. Game is not lagging shots are registering not perfectly but deffinately better than on alienware monitor. Can someone explain what is the problem on this? Shouldnt this be an upgrade?
Things i've tried:
All the response times
Reinstalling nvidia driver
Changing Display Ports
Switching between both 360hz and 240hz no difference
My Specs:
i5-14400f
RTX 4060
16GB ram
on FPS Benchmark avg fps is 398.
shakalaksonya
Re: Alienware AW2724HF problem
Post by shakalaksonya » 26 Jul 2025, 10:24
Can you run cru and take screenshots with one monitor and the other and send them here?
