I have been trying to find a solution for a long time, at times I thought I had found it but most likely it was a temporary placebo. My game runs tragically in spite of a good computer, +500fps, 240 hz monitor and yet my game (at least I think so) runs Wrong. I feel that mouse movements are not responsive, at moments of shooting I feel some lag - even though fps do not drop, I do not see fps drops. Everything works at 100% on 240hz, on the desktop as well as in the game, nevertheless sometimes I feel that it works like 60hz or 60fps. I think I have tried EVERYTHING, from different BIOS settings, to different windows - atlasos, revios. I also tried winutil from chris titus. I have tried 3 DIFFERENT mice, 3 different mousepads, nothing gives any change, I can feel the lags even though they are supposedly small, I can clearly see micro lags at some moments. Feels like screen tearing with lags and fucced up delay. PLEASE HELP.
MY PC SPECS:
RTX 4070
RYZEN 5 7500F
b650 gaming plus wifi
goodram irdm ddr5 2x16gb 6000mhz cl30
valorant feels bad, not smooth, not responsive, micro stutters
sofciik
- kyube
Re: valorant feels bad, not smooth, not responsive, micro stutters
That is a low information answer.
Provide a ZenTimings screenshot, a full list of your system's components, list of peripherals and the software stack you're using (OS, background app sw)
sofciik
PSU msi mag a650bn 650w
ssd wd wds100t3b0e 1tb m.2 2280 pci-e x4 gen4 nvme
fera 5 cooling
currently just stock debloated w11, just as i mentioned i have tried atlasos, revios, winutil - 0 changes
from peripherals its just my mouse (superlight 2) i have tried with 3 different ones and its also the same. Keyboard, monitor, nothing else from peripherals.
- BTN3yI0.png (67.89 KiB) Viewed 5141 times
- kyube
Swap your PSU and SSD as soon as possible.sofciik wrote: ↑24 Jun 2025, 15:52PSU msi mag a650bn 650w
fera 5 cooling
Get a +1000W Corsair AX, RM or Hx PSU or something of similar performance
Get one of the following SSD's: SN8100, 990 Pro, P44 Pro, KC3000, SN850X, T500
Those are severe bottlenecks in your system.
In the meantime:
- Reset BIOS to defaults (disable SMT and EXPO afterwards)
- Run FCLK:UCLK:MCLK to AUTO:1:1
- Install W11 23H2 with .reg file from https://github.com/valleyofdoom/PC-Tuning
This should give you a decent start.
sofciik
yea ill prob buy new psu and ssdkyube wrote: ↑25 Jun 2025, 06:33Swap your PSU and SSD as soon as possible.sofciik wrote: ↑24 Jun 2025, 15:52PSU msi mag a650bn 650w
fera 5 cooling
In the meantime:
- Install W11 23H2 with .reg file from PC-Tuning
i did installed w11 23h2 with .reg file, i did reset bios, its even worse
