Hi there,
I´ve bought a new pc like 4 weeks ago and was very happy with the perormance. Also CS2 was running smooth.
However, today i realized that over sudden there is some sort of ghosting/shadowing... when i move with the agent and move the mouse at the same time like corners or walls these objects seem to lag over sudden ...its hard to describe and hard to capture(i tried with ingame recording its a little noticeable but in real ingame much worse than what you see). I also tried to record it with my phone but there you wont see it.
streamable(dot)com/yam6s2
Anyway....my GPU driver is up 2 date and i have not done any changes.
My specs :
AMD Ryzen 7 9800X3D
AMD Radeon RX 9070 XT
64 GB RAM
Monitor:
SAMSUNG Odyssey G5 LS32DG502EEXXT Gaming Monitor (IPS 2K 180Hz Pivot AMD FreeSync)
Of course settings of the monitor in windows are at 180Hz. Same settings are done ingame CS2.
Attached are my ingame graphic settings and adrenaline settings as well.
Ghosting/Shadowing in CS2 over sudden **SOLVED**
Auronfan02
- settings3
- 3.jpg (191.87 KiB) Viewed 2873 times
- settings2
- 2.jpg (181.61 KiB) Viewed 2873 times
- settings1
- 1.jpg (150.75 KiB) Viewed 2873 times
Auronfan02
Re: Ghosting/Shadowing in CS2 over sudden
Ok found the solution and its not what i expected. So ufo test looked fine so i tried some other fast FPS... tuened out GPU and Monitor aint the problem. My mouse drivers got updated and somehoe the software reset the pollingrate to 125... that caused the lagging. changed it back to 2000 and n oproblems at all.
