(I still don't know what exactly DSC is, so please ignore my ignorance. What I mean by without DSC in this topic is bringing back "Integer Scaling" and being able to create custom resolutions/refresh rates in nvidia control center)
I wanted to use old NVIDIA drivers but DSC won't work below version 536.99 and it only allows you 120 HZ by default.
So I tried to create a custom refresh rate in nvidia control panel and it allowed me up to 334 HZ.
However, if you play a game at a different resolution, you have to add the resolution you're playing at with CRU otherwise the game will work at 120 HZ.
After the resolution was added 330 HZ Is visible.
G60SD Working at 334 HZ Without DSC
*wh!Ssp3r??
Return to “General — Displays, Graphics & More”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — BFI / ULMB / ELMB / DyAc / framegen / LSS / etc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory: Display Science Section
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
