I got a Chinese 1920x1080@600Hz monitor.
But FreeSync wasn't working by default, even though it's what the manufacturer claims. I added the FreeSync Range option and specified 48-240. I can't specify 360/540/600 because they're red and aren't applied. Now FreeSync works at up to 240Hz. How can I increase the FreeSync frequency to 500 or 600Hz?
The monitor is connected via DP 2.1, and the graphics card is an AMD RX 9070XT.
How to increase FreeSync limits above 240Hz?
- F1zus
- Снимок экрана 2026-01-17 042159.png (86.63 KiB) Viewed 14033 times
- Снимок экрана 2026-01-17 042237.png (105.35 KiB) Viewed 14033 times
- RealNC
Re: How to increase FreeSync limits above 240Hz?
I believe the upper limit of the freesync range isn't taken into account to begin with, at least on nvidia. Only the low-end is.
Consider DSC also creates some complications in the ability to create custom resolutions & custom refresh rate ranges.
