How to increase FreeSync limits above 240Hz?
Posted: 16 Jan 2026, 20:27
by F1zus
I got a Chinese 1920x1080@600Hz monitor.
But FreeSync wasn't working by default, even though it's what the manufacturer claims. I added the FreeSync Range option and specified 48-240. I can't specify 360/540/600 because they're red and aren't applied. Now FreeSync works at up to 240Hz. How can I increase the FreeSync frequency to 500 or 600Hz?
The monitor is connected via DP 2.1, and the graphics card is an AMD RX 9070XT.
Re: How to increase FreeSync limits above 240Hz?
Posted: 19 Jan 2026, 11:04
by RealNC
I believe the upper limit of the freesync range isn't taken into account to begin with, at least on nvidia. Only the low-end is.
Posted: 25 Feb 2026, 01:26
Consider DSC also creates some complications in the ability to create custom resolutions & custom refresh rate ranges.
