Persistent “behind the server” feeling in games across multiple PCs & OSes – suspected timing / clock / display pipeline
Rezurrect
Hi,
I’m looking for help diagnosing a long-standing timing / latency issue that I’ve experienced across many different PCs, laptops, operating systems, GPUs, and ISPs.
This is not traditional lag:
Ping is consistently low (10–15 ms)
No packet loss or jitter
High FPS and stable frametimes
Issue is consistent offline vs bots as well
Yet gameplay feels temporally delayed, as if my client simulation is behind the server or behind reality.
Symptoms:
In games like Rocket League, Fortnite, Roblox, Rivals:
Opponents reach the ball first even when I’m visibly closer
I get demo’d / hit after I’ve already jumped or moved
50/50s feel unwinnable
Issue persists even vs bots (e.g. Nexto in Rocket League)
App cold starts on Windows (Explorer, Chrome, Discord) consistently take 5–10 seconds even on fast NVMe systems
Gameplay never feels “correct” or aligned
Critical observations:
Playing remotely on a friend’s PC (remote control / screen share) feels correct and responsive
Cloud gaming does not fix it
One older HP EliteBook laptop worked perfectly
Fedora Linux improves the issue noticeably (especially with gamescope), but does not fully eliminate it
Proxmox + Windows VM did not fix it
Moving the same SSD:
Works fine in a laptop
Immediately has the issue in my desktop
Works fine again when returned to the laptop
This strongly suggests a platform-level timing issue, not OS corruption.
Hardware / OS scope
My Current PC Specs: I5-12400F, 32GB DDR5 4800, AsRock H610M-HDV/M.2, Corsair RM750e, Samsung 980 NVMe, RX 9060XT 8GB.
Tested across:
CPUs: Intel i5-12400F, i9-12900F multiple laptop CPUs
GPUs: RX 580, RTX 2070 Super, RTX 3080, RX 5700 XT, RX 9060 XT
Motherboards: Gigabyte B550, ASUS B760M, ASRock H610M
RAM: DDR4 & DDR5
Storage: multiple NVMe & SATA SSDs
PSUs: Corsair RM750e, CV550
Monitors: Alienware AW2521HF (240 Hz), BenQ Zowie
Ethernet only, multiple NICs, 8+ ISPs
OS tested:
Windows 10, Windows 11, Windows Server 2022, LTSC
Custom / stripped Windows ISOs
Fedora Linux (best so far)
Proxmox (Linux host + Windows guest)
What I’ve already ruled out
ISP / routing issues
IPv6, VPNs
Peripherals
GPU drivers (many versions)
BIOS defaults vs tweaked
C-states, SpeedShift, ASPM, turbo on/off
HPET on/off
Timer tools (ISLC, timer resolution tools)
MSI vs legacy interrupts
DPC latency problems
Current suspicion
This feels like a clock / timing coherence issue, possibly involving:
TSC / QPC instability
Power management affecting clock determinism
Display pipeline buffering (DWM / scanout timing)
Scheduler / compositor behavior
The fact that Fedora + gamescope improves consistency suggests Windows display & timing layers may be amplifying an underlying platform problem.
I’m not looking for generic tweaks or reinstall advice — I’m trying to understand why client timing is consistently late and how to force deterministic timing / scanout.
Any insight from people familiar with:
input lag vs scanout lag
frame pacing vs simulation timing
OS clock behavior
display pipeline latency
would be hugely appreciated.
Symptoms:
Hardware / OS scope
Tested across:
RAM: DDR4 & DDR5
OS tested:
IPv6, VPNs
Peripherals
HPET on/off
Current suspicion
OS clock behavior
- dervu
Re: Persistent “behind the server” feeling in games across multiple PCs & OSes – suspected timing / clock / display pipe
If you suspect timing issues I would check in CPU-Z timers benchmark. If you get any micro stutter visible on countdown then something is wrong for sure.
Rezurrect
Hello,
Thank you for your reply.
I've just ran this, and no micro stutters appeared.
Rezurrect
Just a little update I don't think I mentioned in the original post.
An old HP laptop I used to have ran perfectly fine except for the low fps, also I have had 1 pc (Asus 1660ti, ryzen 5 3600x) that worked fine as well. Another one of my older laptops (1050ti, i7 7th gen) would run perfect on first windows installation boot, then playing a game after restarting once it would mess up, and finally another older laptop I had which was a touch screen one was weird, if touch screen was disabled, games ran weird and delayed, but when it was enabled, it ran fine.
I've had 3 PC's more recently and all have the same issue no matter how much I configure the bios. I'm not entirely sure what causes this issue as it feels like a visual delay rather than ping related.
Phones and a Nintendo switch run fine as well. I really hope someone can help, gaming is just impossible cause I am constantly dying super quick, and in CQCB games, I constantly get hit from so far away, but on their screen I'm like right near them, yet having no stuttering, low(er) ping and a fast setup (with ethernet gigabit speeds)
Master_Tinkerer
I had the same thing with the game being flawless on a fresh install (on win 10/win11), I think some system drivers might be updating automatically. The only way to combat this (somewhat) is to install windows with the ethernet cable unplugged, and then disable driver installations through gpedit.msc>Computer configuration>system>Device installation>Device installation restrictions>Prevent installation of devices that match of these device IDs>Enabled and paste the ID's from device manager>Details>Hardware IDs (you can use any one of those).Rezurrect wrote: ↑23 Jan 2026, 19:38Just a little update I don't think I mentioned in the original post.
But it's still kinda not perfect
Rezurrect
I've tried this with my current PC and PC before it and my girlfriends laptop. This doesn't change anything for me unfortunately. I just don't get why this happens to some but not to all. I've had a canny few friends literally never have this issue and it's so weird.Master_Tinkerer wrote: ↑24 Jan 2026, 08:17I had the same thing with the game being flawless on a fresh install (on win 10/win11), I think some system drivers might be updating automatically. The only way to combat this (somewhat) is to install windows with the ethernet cable unplugged, and then disable driver installations through gpedit.msc>Computer configuration>system>Device installation>Device installation restrictions>Prevent installation of devices that match of these device IDs>Enabled and paste the ID's from device manager>Details>Hardware IDs (you can use any one of those).Rezurrect wrote: ↑23 Jan 2026, 19:38Just a little update I don't think I mentioned in the original post.
Cosmostraveler
I am currently trying your version, making sure no updates are done and that gpu driver is installed manually (without internet every connecting) and updates disabled permanently. I tried this yesterday too (delaying updates at first) but it still downloaded some security updates as well as Microsoft Removal Tool, and some AMD drivers, again, despite updates being paused. Now, im running all vanilla (no updates at all). Another thing that definitely improved the input lag (which is recreatable) is to put Microsoft Defender Compatibility to Windows 7. There will be 2 .exes, one is msmpeng and another is a core service I believe. Try this out and let me know if you can see the difference. I know installing Bitdefender completely removes these exes mentioned above from running, hence giving the similar feel.Master_Tinkerer wrote: ↑24 Jan 2026, 08:17I had the same thing with the game being flawless on a fresh install (on win 10/win11), I think some system drivers might be updating automatically. The only way to combat this (somewhat) is to install windows with the ethernet cable unplugged, and then disable driver installations through gpedit.msc>Computer configuration>system>Device installation>Device installation restrictions>Prevent installation of devices that match of these device IDs>Enabled and paste the ID's from device manager>Details>Hardware IDs (you can use any one of those).Rezurrect wrote: ↑23 Jan 2026, 19:38Just a little update I don't think I mentioned in the original post.
Sandy
All of this is due to the graphics card driver.Rezurrect wrote: ↑21 Jan 2026, 15:57Hi,
Symptoms:
Hardware / OS scope
Tested across:
RAM: DDR4 & DDR5
OS tested:
IPv6, VPNs
Peripherals
HPET on/off
Current suspicion
OS clock behavior
Rezurrect
Hello, thank you for your response.Sandy wrote: ↑25 Jan 2026, 08:54All of this is due to the graphics card driver.Rezurrect wrote: ↑21 Jan 2026, 15:57Hi,
Symptoms:
Hardware / OS scope
Tested across:
RAM: DDR4 & DDR5
OS tested:
IPv6, VPNs
Peripherals
HPET on/off
Current suspicion
OS clock behavior
I've tried multiple GPU driver versions, including searching up multiple best stable driver versions for both AMD and Nvidia GPUs when I've had either one, and nothing fixed it.
Sandy
The origin of all these problems can be traced back to the time Intel released dual-core processors. Since then, operating systems have introduced a new slicing mechanism. Explaining this issue in detail would be too complex.Rezurrect wrote: ↑25 Jan 2026, 18:06Hello, thank you for your response.Sandy wrote: ↑25 Jan 2026, 08:54All of this is due to the graphics card driver.Rezurrect wrote: ↑21 Jan 2026, 15:57Hi,
Symptoms:
Hardware / OS scope
Tested across:
RAM: DDR4 & DDR5
OS tested:
IPv6, VPNs
Peripherals
HPET on/off
Current suspicion
OS clock behavior
In short, don't waste your time elsewhere. Try using a 3060 graphics card with driver version 552.22. You can try this combination; some old-school gamers who experience no input lag recommended this perfect graphics card and driver combination to me (it must be a 3060, not a 3060Ti). However, brand new 3060 graphics cards are no longer available; only used ones can be found on the market. The good news is that Nvidia is preparing to restart production of the 3060.
