I sold my pc but i will be back and I investigate this problem
Hubcio
So… I checked my monitor and I hear in my IEMS sound in it(electromagnetic sound or what?) also I hear heavy sound from ps3 when I’m not using it- electromagnetic too?
Should I now check all sockets in the house and try to find perfect one without any sounds? It’s so weird tho XDDD I just can’t… guys I can’t believe wtf is going on for real.
Hubcio
Re: I sold my pc but i will be back and I investigate this problem
Is it electromagnetic interference sound? Monitor and router, here is sound video:
https://youtube.com/shorts/HVEO5Rfd0q0? ... gCWDpNhaoL
Hubcio
I also found lightning bulb making noise in one room:
https://youtube.com/shorts/_ZSHYvdeSRk? ... 47eV18vtEi
Am I living in the nightmare or wtf
Hubcio
Kitchen hood making noises too when I switch on lightning in it- is it normal?
https://youtube.com/shorts/QxLcnqj9ZU8? ... 4Wtzax_1Eq
MK92
Unstable neutral, high impendance and ground loops....classic signs showing up in other appliances. Turn on all lights around the house in every room, and then also turn on washing machine, stove, kitchen hood, microwave etc., and check if the lights would flicker immediately when the appliances are turned on.
And I bet you could also hear your speakers buzzing when you turn the computer OFF, since it would pick up the noise on neutral?
- Slender
download "spectroid" and check what frequency cause that
Hubcio
Do you think guys if I will rewire my room and install independent electricity meter only for my room it could work? Also my house has only 6kW power, so can I increase kW only for my room? Or it only works after a whole house rewiring? Because power company doesn’t want to increase kW for our house in reason of old electrical installation.MK92 wrote: ↑25 Feb 2026, 04:31Unstable neutral, high impendance and ground loops....classic signs showing up in other appliances. Turn on all lights around the house in every room, and then also turn on washing machine, stove, kitchen hood, microwave etc., and check if the lights would flicker immediately when the appliances are turned on.
In our house we have 3 tvs, 2 washing machines, 2 fridges and of course lightning, maybe low electrical power is causing it
- Slender
No, it's completely pointless. People just don't want to look for solutions to their problems; they want to live in their own hallucinations. Yeah, dude, do it, change the wiring.
- Slender
I completely understand Chris, this forum is the reason why I don't publish the fix.
1nputlag34
