Hello there. Here's my story.
I had BenQ Zowie XL 2566K 360 Hz (TN Panel) for 3 years. It was OK, I had some issues with coil whine, they got solved in RMA process.
However, I decided to upgrade my monitor. So I went for new XL2566x+ model. And then, the problem started.
First unit, had terrible pixel inversion artifacts, causing eyestrain. I returned it the next day. I decided to play panel lottery again and ordered another unit. This time it was way better. However, that's where the real problem started.
When I was moving in games, specifically from left to right or right to left (horizontally, in general), I immediately noticed scanlines-like pattern appearing on solid colors (i.e. portals in Diablo 2 Resurrected, bright walls in CS2). It was really distracting. Because of this, I also tried 2 other units of 2566x+, it was all the same.
I contacted Zowie support, also did some basic troubleshooting, like settings rest, disabling Dyac, overdrive, etc - no success. However, later I ordered 2586X+ just to check if the issue is there too. And yes, there is. Idk even how to call it - it's propably pixel inversion artifact again, but it's really, really strange.
I also got and OLED, everything is fine there.
While doing some troubleshooting, I tried lowering the refresh rate from 600 Hz to 240 Hz - and guess what - the issue is gone. However, this monitor is expensive and I want to use it's full potential, so you know, I'm not happy about using it on lower refresh rates.
I'm stuck atm. I like the monitor in general, but this issue is stinging me. And I also doubt, swapping units can help - I had total 5 of these new Zowies, all exhibited the same issue in general.
I just want to know, if anyone of you have the same experience with these new Zowies - or is there anything else I can do in that case? Or maybe there's somethings wrong with me instead? Thank you for your input.
Regards
Mike
There's something wrong with new Zowie monitors - or with me
adx56
- kyube
Re: There's something wrong with new Zowie monitors - or with me
Make a custom resolution in Nvidia Control Panel till you find a resolution that's comfortable for you.adx56 wrote: ↑05 Mar 2026, 12:29While doing some troubleshooting, I tried lowering the refresh rate from 600 Hz to 240 Hz - and guess what - the issue is gone. However, this monitor is expensive and I want to use it's full potential, so you know, I'm not happy about using it on lower refresh rates.
Try 540, 500, 480, 400, 360, 333, 300
You could be sensitive to DSC.
Use the HDMI 2.1 port of your 86X+.
adx56
Thank you for your reply. Altough, I want to use the monitor to it's full, it's pricey, I don't feel good when I'm forced to limit it just to make it look "right".
I just wonder, why on 500 Hz here it seems fine, but on XL2566X+ the issue persisted on 400 Hz. That's strange, isn't it?
- kyube
Are you saying that it's fine on XL2586X+ @ 500Hz? Interesting, if so. Is there a chance that you could try and capture the effect with a smartphone camera?adx56 wrote: ↑05 Mar 2026, 14:30Thank you for your reply. Altough, I want to use the monitor to it's full, it's pricey, I don't feel good when I'm forced to limit it just to make it look "right".
It's not a “forced to limit it” situation IMO. These high Hz TNs are generally better when set to a lower refresh rate.
There's a slight chance that the display comes with a frame-skipping resolution or inversion artifacts are more noticable to you.
The XL2566X+ @ 400Hz may also be susceptible to inversion artifacts OR some form of DSC (as it's right on the edge). Though, the latter is highly unlikely to be the issue.
Most Zowies seem fine, but I've met a few Zowie's that has... ehm... the worst inversion artifacts I've seen.
LCD inversion artifacts definitely goes down the lower Hz you go. Inversion artifacts have long been common on TN LCDs, much moreso than VA and IPS.
Sometimes it can be much worse (more visible chess board) than this bad one:
The chess board alternates (flickers!) every opposite refresh cycle. And the patterns show up/disappears at different motion speeds. The flicker-like artifacts can disappear/reappear at 1ppf, 3ppf, 5ppf, 7ppf, but disappear at 2ppf, 4ppf, 6ppf (Pixels Per Frame). You can adjust motionspeeds at TestUFO and watch the inversion artifacts appear/disappear or go weird.
Sometimes it's like interlacing instead; horizontal lines or vertical lines instead of a chessboard, but it's usually a chessboard. Inversion algorithms on different brands can have different patterns, subpixel, or full pixel.
So annoying. Generally, this is the worst kind of LCD flicker when the TN LCD has inversion with far bigger flickerdepth than FRC and temporal dithering.
I am never bothered by FRC or temporal dithering, but poorly-calibrated LCD inversion algorithms are my pet peeve. They should flicker at less flickerdepth than FRC or temporal dithering, but man... I've seen inversion artifacts 100x worse than FRC or temporal dithering. It doesn't strain my eyes (like it does some), but it distracts me during gameplay.
Experiment with different custom refresh rates in ~50-100Hz steps between 240-600Hz and see how high you go before inversion artifacts appear. In an ideal world, an inversion algorithm would use pseudorandom noise instead of patterned noise, so it's at least consistent at all refresh rates.
Eyestrain from the flicker of extremely bad LCD inversion artifacts can be worse than FRC and temporal dithering for some people, sadly... Over the years I've seen really nasty LCD inversion that's 100x more visible than a good TN panel. It's like a strong chessboard artifact where every opposite diagonal pixel is 50% brighter/darker than the adjacents. And alternates (flickers) every refresh.
Sometimes it's a panel batch, have to try to get it from a different panel batch (e.g. different month of manufacture, different online store, different firmware) to see any differences.
Or use a ultrahigh-Hz IPS. IPS is mostly immune to inversion artifacts, though low-bitdepth IPS may use FRC/temporal dithering. FastIPS can perform as well as yesteryear TN, but e-TN is even faster again (but beware of inversion artifacts).
Since you have observed eyestrain reduction from OLED, I would suggest trying a 480Hz, 540Hz or 720Hz OLED as an easier ergonomic path. On average, ergonomically speaking, the pixel refreshing logic tends to be far less bothersome than the average TN LCD.
Explanation of artifacts from inversion: viewtopic.php?p=28881#p28881
Ancient reading material about why inversion algorithms exist in LCDs (sometimes visible, sometimes invisible)
http://www.techmind.org/lcd/index.html#inversion
http://www.lagom.nl/lcd-test/inversion.php
Voltage inversion is a necessary part of LCDs, but artifacts that occur from voltage inversion, is a part that can cause known ergonomic problems that are easier to trigger headaches/discomfort on some esports TN LCDs.
Note: you can have FRC+inversion layering on top of each other, making things worse. Ouch. But very unbalanced inversion is always massively more visible than FRC or temporal dithering, since FRC is just flickering between adjacent pixel colors, while very unbalanced inversion is a much bigger flicker depth
Note: Zowies can vary a lot -- one model 10x more intense inversion artifacts, then a few months later a new firmware and a new factory lottery run, much fainter. Or vice versa. But TN LCDs are perpetually at risk of blatantly annoying inversion artifacts. While IPS and OLED is immune. It's a price you dearly pay for ultra-fast-pixel-response TN LCDs, the faster the pixels go, the more the positive:negative voltage pixels are not equal brightnesses, as it's mere millivolts differences to go awry.
