Ok guys i'm kind of confused with all these different models of monitors.
I'm looking for a good FPS monitor that can give me the lowest input lag as possible, which monitor will I be after?
I was looking at the XL24020g, with shipping it costs me around $750~
price being said is there any other alternative for XL2420g ?
I decided to get XL2420z however I saw XL2411z What are the differences? as in, is the internal hardware different or the LCD panel? Do they both produce same amount of input lag ?
Also can you have both Lighboost enabled with Gsync?
price over performance is it worth getting the XL24020g over a XL2411z ?
Are there known issues with XL2411z or XL2420z (that should be avoided) ? Please enlighten me.
Cheers.
Which Monitor ? [Q]
Falkentyne
Re: Which Monitor ? [Q]
2411Z does not have displayport.
2411Z doesn't have the S-switch (rather handy)
They're the exact panel, so no differences in performance
- masterotaku
Same panel.raiden wrote: is the internal hardware different or the LCD panel?
At the same time? No, but the Z series monitors don't have G-Sync anyway.raiden wrote:Also can you have both Lighboost enabled with Gsync?
The XL2420G is so expensive that it makes more sense to get an Asus Rog Swift (real 8bit colors, 1440p, G-Sync), paying a bit more. Unless you need blur reduction at any refresh rate, like 60Hz, and also want G-Sync.raiden wrote:price over performance is it worth getting the XL24020g over a XL2411z ?
In my opinion, it's not worth the cost over a XL2411z. I "can't" play without motion blur reduction. However, the Z series monitor have a drawback: overdrive artifacts.
ULMB in G-Sync monitors should be better in this respect.
Edit: this is with Lightboost:
Original and big screenshot here: http://i.cubeupload.com/8fRGYu.jpg
See above.raiden wrote:Are there known issues with XL2411z or XL2420z (that should be avoided) ?
Monitor: Asus PG278QR
Sweet thank you all. I guess i'll be just happy with a xl2420/11 z + lightboost enabled.
It's going to be a great upgrade from an old 60hz monitor.
