CPU 13th Generation Intel® Core™ i7-13700KF
2x 16 gb corsair vengeance 6000mhz xmp ddr5
1x NVIDIA® GeForce RTX™ 4080 16GB
Windows 11
2.5gb Realtek ethernet card
Currently high performance power plan
Win32Prio set
MMCSS disabled
backgrounds apps disable
HPET disable tested both onvsoff On is terrible!
etc
The system does have tweaks done, currently I have Ecores and hyper threading turned off in bios as well.
I was getting longer dips in FPS with these enabled.
The issue is I am getting a CPU bottleneck in scenes that involve explosions and rendering of fire. The game is call of duty BO7, the incorporated benchmarking tool shows sharp dips in a FPS and a increase in a CPU Time in ms's anywhere from 4ms-8ms.
I'm running both vsynch and gsynch with Reflex plus boost and nvdia dlss upscaling. As the tearing and stuttering was too much otherwise. There was no fluidity. Even still I get the player characters teleporting/skipping if you will during movement and gunfights.
Any clues on how to mitigate this? Excuse me if this is the wrong place for this. Just feel like the machine should perform better than it does. It is a Lenovo legion prebuild btw so there is only so much I can do about certain things. I'm just curious if anyone has seen and fixed this particular problem as it's difficult to say exactly what without knowing exactly what's been done and is happening with the system.
System underperforming, CPU Bottleneck
GrumpySav
Re: System underperforming, CPU Bottleneck
Adding some pictures
- Untitled3.png (1.1 MiB) Viewed 83716 times
- Untitled2.png (1.11 MiB) Viewed 83716 times
- Untitled.png (848.84 KiB) Viewed 83716 times
- kyube
Sell it / return it and get a proper PC.
The SW tuning you've done is more disadvantageous than advantageous.
