Vsync Vblank and 1/2 Vsync interaction
Crit
Post by Crit » 23 Mar 2026, 10:27
I have a small question regarding the usage of double buffered v-sync. Specifcally when using its 1/2, 1/3 and 1/4 versions and the utilization of Vblank.
Let's say we have 240hz, so vblank comes every scanout which is every 4.16 ms. Now using 1/2 V-sync the Vblank is expected every 1/120 = 8.33 ms. Does this mean the system appoints one of the 2 possible scanouts as the Vblank position or does it actually have the ability to use both? Say it fails the 8.33 ms render time and it finishes after 9 ms. Will it use the next potential scanout arriving in 3.48 ms or will it skip one and wait for the next one arriving in 7.64 ms?
Re: Vsync Vblank and 1/2 Vsync interaction
Post by RealNC » 23 Mar 2026, 10:34
It will do the exact same thing as if you were running 120Hz vsync ;-) So it always skips the vblank that wouldn't exist if it was running 120Hz.
Crit
Post by Crit » 23 Mar 2026, 12:53
Thank you for your response!
So that means running monitor at 240hz 1/2vsync or running it at 120hz at vsync is the exact same right? Then I'll just lower it to 120Hz and use 240Hz if I need to run 1/3 vsync (80hz) for performance reasons.
Post by RealNC » 23 Mar 2026, 17:57
Crit wrote: ↑
23 Mar 2026, 12:53
It's not the same because you get faster scanout at 240Hz, so display latency is lower compared to 120Hz. But from a frame pacing perspective, it is exactly like 120Hz.
