Microtearing,blur,fuzzy graphics
Ali191
Post by Ali191 » 23 Mar 2026, 18:38
Pc showing fuzzy,blurry,microtearing graphics
in fortnite performance mode and
Valorant
List of optimizations done:
-HAGS(hardware acceleration gpu scheduling)OFF
-RESIZABLE BAR ON
-FSO (FULLSCREEN OPTIMIZATION) OFF
-CAPPING REFRESH RATE FPS UNDER 3 FPS
-DISABLING MPO(MULTI-PLANE OVERLAY)
-TURNING ON V SYNC + G SYNC
-TURNING ON G SYNC FULLSCREEN ONLY
-RESETING MY PC
-UPDATING DRIVERS:BIOS,CHIPSET,AND NVIDIA DRIVERS
-RESETING PC TO OLD WINDOWS SOFTWARE 23H2
-UNPARKING CPU
-NVIDIA CONTROL PANEL OPTIMIZATIONS
-TRYING DEBUG MODE
-DISABLING GLOBAL C STATES,CPPC AND CPPC PREFFERED CORES IN BIOS
-CHANGING DISPLAYPORT
-CHANGING MONITERS
-CHECK REFRESH RATE IN WINDOWS AND SETTING IT TO HIGHEST
-CHANGING PCIE SLOT GEN FROM AUTO TO GEN 4 AND GEN 3
-DISABLING FAST STARTUP
-UNISTALLING GPU DRIVERS BY DDU UNINSTALLER AND REINSTALLING BY NVCLEANSTALL
‐TRYING STABLE NVIDIA GPU DRIVERS SUCH AS 566.36 AND 581.29
-CHANGING POWERPLAN "BALANCED" TO "HIGH PERFORMANCE"
-SCALE SET TO 100%(RECOMMENDED)
-CHANGING TO A NEW GPU
Important note:
-Unplugging and plugging the displayports fixes the graphics for 3 minutes until the issue reoccurs
-Capping fps to refresh rate makes the rendering worse=more microtearing,fuzzy and blurry gameplay
-HDMI doesn't fix it & changing moniters
-I am on the latest nvidia driver
My specs:
RTX 3060 12gb
Amd ryzen 5 5600x
16gb ddr4 ram
1tb ssd
650watts psu
B550M ds3h motherboard
Screenshot_20260305_180931_Video Player.jpg (215.29 KiB) Viewed 5947 times
Screenshot_20260305_180921_Video Player.jpg (219.42 KiB) Viewed 5947 times
Screenshot_20260305_180857_Video Player.jpg (226.15 KiB) Viewed 5947 times
Sandy
Re: Microtearing,blur,fuzzy graphics
Post by Sandy » 25 Jul 2026, 05:25
I'm also troubled by this, and most people have this problem too, but they all think it's a problem with the mouse brand. What I can confirm now is that it might be a specific brand of motherboard and a 3060 graphics card paired with a graphics driver version 552.22? You could try this combination.
I observed someone who is the only person I've seen without any typing lag, but he streams on the Chinese version of Douyin (TikTok). I don't know if you can use this software.
This is his Douyin account homepage. Copy the following content and paste it into the software to see his account. He streams almost every day, but maybe at the opposite time to yours. You can also search for "CS小孩" in the software.
4- Long press to copy this message, open Douyin and search to see more of his/her work. https://v.douyin.com/8v4ezfgtp3a/ [email protected] :1pm
