Leaving Lightboost On
Roleplay
If I leave this on all the time, will it damage my monitor in any way?
- Karnaj
Re: Leaving Lightboost On
This is from the LightBoost FAQ:
Q: Does LightBoost shorten the life of the monitor’s backlight?
No. LightBoost is a built-in function of a monitor. It is a part of nVidia 3D Vision.
LED’s do not undergo meaningful wear and tear by being turned on/off, when done within the LED’s power specifications. LightBoost is simply a low-frequency motion-optimized PWM (pulse-width modulation), and is dimmer than non-LightBoost 100% Brightness. LED stand for Light Emitting Diode, which are semiconductor devices. They are also used for fiber optic cables that do not use lasers, such as TosLink (LED’s that switch on/off millions of times per second!).
ASUS VG248QE | ASUS P8Z77-V | Intel i5-3570k @ 4.5 GHz | EVGA GTX 780 Classified ACX | Razer Deathadder 2013 | CM Storm QuickFire Rapid Red Switches | Seagate Barracuda 2TB 7200 RPM | Cooler Master Storm Scout 2 Advanced | Antec HCG-750
Related thread: http://forums.blurbusters.com/viewtopic.php?f=4&t=99
In other words, it's nothing to worry about. You can leave LightBoost ON, if you wish.
