Anyone have this monitor? I haven't seen any discussion about it probably cuz it's relatively new.
Anything unique or interesting about it?
MSI - MAG 275QPF X30
mango87
Re: MSI - MAG 275QPF X30
I purchased this monitor and returned it. It has red phosphor so I would not recommend using its' BFI unless you're ok with seeing a red trail. Other than that, it's nothing special besides the 300hz and VRR. There wasn't anything wrong or noteworthy, but I returned it because I wanted good strobing.
Argus
Interesting. Did the monitor have good colors out the box? the red phosphor part is interesting because I suspect my current Omen 27qs monitor has decaying red phosphor because the colors have slowly become more yellow-reddish overtime in SRGB mode. Whites are not fully white and there's a slight tinge of yellowmango87 wrote: ↑24 Mar 2026, 23:09I purchased this monitor and returned it. It has red phosphor so I would not recommend using its' BFI unless you're ok with seeing a red trail. Other than that, it's nothing special besides the 300hz and VRR. There wasn't anything wrong or noteworthy, but I returned it because I wanted good strobing.
mango87
It's a wide gamut monitor so everything will look saturated out of the box. There is an sRGB mode. I didn't notice any uniformity problem. Then again, I'm used to IPS glow.Argus wrote: ↑25 Mar 2026, 07:39Interesting. Did the monitor have good colors out the box? the red phosphor part is interesting because I suspect my current Omen 27qs monitor has decaying red phosphor because the colors have slowly become more yellow-reddish overtime in SRGB mode. Whites are not fully white and there's a slight tinge of yellowmango87 wrote: ↑24 Mar 2026, 23:09I purchased this monitor and returned it. It has red phosphor so I would not recommend using its' BFI unless you're ok with seeing a red trail. Other than that, it's nothing special besides the 300hz and VRR. There wasn't anything wrong or noteworthy, but I returned it because I wanted good strobing.
