EMI or Desync?
aress
EMI or Desync?
Post by aress » 29 Mar 2026, 07:04
Hey, I need help figuring out if this is an EMI issue or not. I have this desync/input lag problem where I can hardly control any gun recoil—hitting enemies is legitimately difficult, and I lose about 95% of my fights. On top of that, the audio becomes completely broken—key sounds don’t play on my headset, and a lot of surround sound I hear in stream POVs simply doesn’t exist.
For most days of the month—like 3/4—I have this issue. But there are days where the issue is completely gone. On those rare days, I can literally steamroll people, one clip enemies without any problems, and the audio is perfect.
I’ve tried two different PCs, different mice, keyboards, and headsets—none of it helps. I’ve reinstalled Windows multiple times and updated all my drivers, but I’ve never been able to maintain that “normal” feeling I get on those rare good days.
aress
Re: EMI or Desync?
Post by aress » 30 Mar 2026, 04:07
I have tried 3 different PSUs lol, 2 gold and 1 platinum-rated 850 watt.
Re: EMI or Desync?
Post by Slender » 30 Mar 2026, 20:43
aress wrote:
30 Mar 2026, 04:07
all doesnt work with your setup
Cosmostraveler
Re: EMI or Desync?
Post by Cosmostraveler » 31 Mar 2026, 08:01
aress wrote:
30 Mar 2026, 04:07
I soon need to replace my PSU. What are the ones you have tried and have not been successful in improving your situation?
MK92
Re: EMI or Desync?
Post by MK92 » 31 Mar 2026, 08:36
Gold/platinum rating is not important at all, the important things are transient response on 5V and 3.3v rails, low ripple, active PFC quality, capacitors quality, DC-to-DC build quality..."platinum" is just an efficiency rating for saving money and nothing else, it makes no difference for bad electrical input.
Cosmostraveler
Re: EMI or Desync?
Post by Cosmostraveler » 31 Mar 2026, 13:28
MK92 wrote:
31 Mar 2026, 08:36
Can we get some budget options?
MK92
Re: EMI or Desync?
Post by MK92 » 31 Mar 2026, 14:36
DeepCool PSUs are actually good at handling bad electricity, but if the problem is shared neutral / impedance then it won't help, not even a PSU for 600€ would help in that case
Cosmostraveler
Re: EMI or Desync?
Post by Cosmostraveler » 01 Apr 2026, 02:39
MK92 wrote:
31 Mar 2026, 14:36
DeepCool Gamer Storm PN1200-M R It's around 150 euros for me. I just thought there are better options at this price quality wise, obviously less W.
MK92
Re: EMI or Desync?
Post by MK92 » 01 Apr 2026, 03:16
Try PN850M 850W for about 110€, you don't need more wattage than that unless you have rtx 5090
