[GIGABYTE] INPUT LAG IN BIOS AND WINDOWS
nickchraj
Post by nickchraj » 29 Mar 2026, 11:57
Has anyone experienced something similar?
In the PC Health section of the BIOS, my mouse feels extremely laggy—almost like it’s running at ~20 Hz. I’ve also noticed this behavior in other BIOS sections where values are constantly updating (e.g., voltages, temperatures). The cursor movement becomes noticeably less responsive in these areas.
Video proof -> streamable [dot] com/fm6xgh
Additional Observations
I also experience input lag in Windows and in games, although it’s less pronounced compared to the BIOS issue.
I’ve been dealing with general input lag problems for years, across different hardware setups.
However, this particular issue in the BIOS is much more obvious and severe.
through out the years, i tried every possible tweak hack to medicate the input lag but nothing works, even the absurd suggestions posted without any good results, though sometimes randomly at night my mouse gets snappier for few minutes and then beaks,
Ive tried multiple locations and multiple systems,
Id really appreciate some help if someone has dealt with this before.
System Specifications
Motherboard: Gigabyte Gaming X Z690
CPU: Intel i7-12700K
RAM: 16GB (Dual Channel, Trident Z, CL18 3600 MHz)
GPU: RTX 3080 (10GB)
Cooling: AIO Cooler
PSU: 850W+
nickchraj
Re: [GIGABYTE] INPUT LAG IN BIOS AND WINDOWS
Post by nickchraj » 29 Mar 2026, 12:13
Kinda tried everything on this forum so not expecting much :lol:
naporitan
Post by naporitan » 29 Mar 2026, 15:46
Why use a mouse in BIOS? If everything is done with the arrow keys.
nickchraj
Post by nickchraj » 29 Mar 2026, 16:09
naporitan wrote: ↑
29 Mar 2026, 15:46
The point of this post is to find a solution for the input lag in windows and games
Dusky
Post by Dusky » 29 Mar 2026, 17:56
Yep, I just got an AMD 9070 XT. First AMD GPU I ever purchased and there's a tab in the software for performance/tuning. Whenever I open that up it runs like shit. Well,not really like shit but it's definitely not smooth.
Post by Slender » 29 Mar 2026, 21:26
naporitan wrote: ↑
29 Mar 2026, 15:46
ahahahahhahahaha that a reason why fix never arrived this forum
Cosmostraveler
Post by Cosmostraveler » 30 Mar 2026, 04:55
nickchraj wrote: ↑
29 Mar 2026, 11:57
Cooling: AIO Cooler
PSU: 850W+
I recently purchased a Gigabyte board (a budget one) cuz my old ASUS died. In my BIOS (all bios versions) the mouse is UNUSABLE. Literally 1 hz. The mouse takes between 2 to 3 seconds to move. Yes. seconds. The keyboard works just fine inside BIOS.
mago
Post by mago » 30 Mar 2026, 13:39
try flashback the newest bios , get the bios using other pc to be sure it wont get infected
Ⓢк𝕀lŁ เ𝓢 ᵗⒺм𝕡σr𝐀𝐑Ⓨ, lά𝔾 I𝐬 F𝔬ʳ𝔢𝓿ᗴ𝔯
Sandy
Post by Sandy » 19 Apr 2026, 01:01
I am experiencing this issue as well: within the BIOS, my mouse sensitivity drops to a speed equivalent to roughly 100 DPI. Currently, there is no explanation for this phenomenon—and, notably, the degree of the speed reduction varies significantly depending on the specific mouse being used.
Bobo
Post by Bobo » 19 Apr 2026, 07:44
i will never again, buy gigabyte mobos or gpus, they`re horrible, the mobo's bios has many features missing.
