CRU - custom refresh rates causing eyestrain?
There are over 100 ergonomic issues from displays, far more than just flicker and blue light. This forum covers the giant variety of display ergonomics issues.
Argus
Post by Argus » 01 Apr 2026, 22:24
I've noticed that when I make a custom refresh rate, even with correct timings, the new refresh rate causes immense eyestrain to the point I can barely look at the monitor. I've tested this on multiple monitors: omen 27qs, acer pulsar XB273U, and asus XG27AQDMG.
The reason I want to make a custom refresh rate is because I'd prefer 180hz for most content but none of the above monitors have this built in. I have enough fps for 180hz and 180hz also works well with most web content which runs at 30/60 fps. Also some games I play have a weird bug where using gsync and capping fps to below the refresh rate will cause stutter so I can't simply just use 240hz and be done with it.
what could be going on here?
