CRU - custom refresh rates causing eyestrain?
Posted: 01 Apr 2026, 22:24
by Argus
I've noticed that when I make a custom refresh rate, even with correct timings, the new refresh rate causes immense eyestrain to the point I can barely look at the monitor. I've tested this on multiple monitors: omen 27qs, acer pulsar XB273U, and asus XG27AQDMG.
The reason I want to make a custom refresh rate is because I'd prefer 180hz for most content but none of the above monitors have this built in. I have enough fps for 180hz and 180hz also works well with most web content which runs at 30/60 fps. Also some games I play have a weird bug where using gsync and capping fps to below the refresh rate will cause stutter so I can't simply just use 240hz and be done with it.
what could be going on here?
