Will 1000 Hz make VRR redundant?
peppermintie_
Post by peppermintie_ » 10 Apr 2026, 11:54
I wonder, would 1000 hz be close enough to become analog and there would be no need for vrr (avoiding vlicker, gamma shift etc). Im currently using 240 hz oled and running games without vrr feels okay, dont know if 480 hz makes it much better tho. Technically 1000 hz would be 1ms of potential frame mismatch, it would refresh fast enough to make tearing and judder imperceptible to us i guess. What do you think?
Espionage724
Re: Will 1000 Hz make VRR redundant?
Post by Espionage724 » 10 Apr 2026, 15:15
I think I'd find a CRT somewhere before considering throwing 1000Hz into the mix :p
If LCD needs that kind of power to be comparable to old tech, how's the newer tech better? Any tricks done before the image outputs to my screen for eye-looking is slower abstraction/higher latency than just displaying the image as fast as possible, and there's only so much physically to be done with moving liquid vs an electron beam.
Post by RealNC » 11 Apr 2026, 00:34
Espionage724 wrote: ↑
10 Apr 2026, 15:15
A CRT wouldn't help with motion judder. Which is what VRR helps with. 50FPS for example on a 60Hz CRT has the same judder as on LCD and OLED. Or any situation where refresh rate isn't an integer multiple of the frame rate.
1000Hz definitely helps with that. On CRT too. If there was a 1000Hz CRT (somehow), 50FPS@1000Hz will have much less judder. Probably so low as to be invisible. The word is "probably", who knows for sure until 1000Hz arrives.
There's some 720Hz screens out there (those "dual mode" ones), but no one even did a test for this in their reviews, even though that would be the first thing I'd test :-/
