Nothing has ever helped me better than this. I believe in electric input lag, but this guide helps ME greatly improve my gameplay with this issue
1. Remove all Intel-related drivers (chipset, DTT, etc.) In my experience, every Intel driver causes a huge delay.
2. Realtek Audio Driver - remove it and never install it again!
3. If your router is in the same room with you, do not use the mouse dongle. Disabling the 2.4 GHz network may not help. Try using the mouse exclusively with a wired connection for at least a day!
4. Issues with latency when anti-cheat is enabled:
Create a separate user on your system with administrative privileges.
Transfer the anti-cheat service to the new user with administrative privileges.
This can help you not only with FACEIT AC, but also with other anti-cheats!!
FACEIT AC INPUT LAG | SYSTEM INPUT LAG REDUCING
- zeasty09
Re: FACEIT AC INPUT LAG | SYSTEM INPUT LAG REDUCING
How exactly?deplovnet wrote: β11 Apr 2026, 12:09Nothing has ever helped me better than this. I believe in electric input lag, but this guide helps ME greatly improve my gameplay with this issue
deplovnet
Hi, sorry for the long response.zeasty09 wrote: β11 Apr 2026, 21:43How exactly?deplovnet wrote: β11 Apr 2026, 12:09Nothing has ever helped me better than this. I believe in electric input lag, but this guide helps ME greatly improve my gameplay with this issue
1. Create a new user in the system with ADMINISTRATOR rights - this is important!
Then go to "services" in Windows and search for Faceit, and set it to run as a new user.
2. Download Process Lasso and remove the 0 and 1 cores when running faceit ac, this helps a lot
