New monitor
ama22
New monitor
Post by ama22 » 04 May 2026, 14:10
Hello, im in search of a new monitor to connect to my lenovo loq 15ARP9 rtx4060 ryzen 7 7345
Since the small display has been making it difficult for me to play fps games as i would want to. The problem is that i've tried searching a gaming monitor at at round 200-250 euros but got no idea which one to choose. I got documented initially in terms of clarity viewing distance etc the basic stuff and now i found about motion clarity. I was looking for a qhd 240 hz initially but then got introduced to mbr and got completely lost as to which monitors would actually provide me the best motion clarity and smoothness for the games i want to play. I mostly play cs val and apex and league andvrarely story games/single player games. I was eyeing the aoc q27g4zr since i found it at 180 euros, is there something better in terms of clarity smoothness with overdrive settings etc for fps games.
In cs2 and val im playing with gsync vsync on because the tearing is tremendous without it. Any suggestions, tips or information is welcomed. Sorry for the long story
Dalek
Re: New monitor
Post by Dalek » 06 May 2026, 19:33
Check out the AOC Q27G4SRU (recommended by kyube)
or the Q27G4ZR (the one you were already looking at).
kyube
Re: New monitor
Post by kyube » 06 May 2026, 21:07
Dalek wrote:
06 May 2026, 19:33
AOC Q25G4SR
Fixed that for you. I haven't recommended that 27" model you've suggested anywhere.
Also, Titan Army P245MS Pro, if from Russla / Japan / China.
I'd only go 27" if 4K (e.g.: KTC M27P6) or 5K (e.g.: ASUS XG27JCG / MSI 271KRAW16), not 27" QHD.
ama22
Re: New monitor
Post by ama22 » 08 May 2026, 18:17
kyube wrote:
06 May 2026, 21:07
Dalek wrote:
06 May 2026, 19:33
AOC Q25G4SR
unfortunately that titan army model is a bit out of my budget, would you say this one TITAN ARMY P2510S PLUS is good enough for the 180-200 price range and if yes which one would you choose, this model or the aoc mentioned above
