Hi everyone,
I've been investigating this issue for several months and would really appreciate input from anyone with experience in power quality, EMI/RFI, EMC, or electrical engineering.
At this point, I've already gone through all the usual software troubleshooting (Windows, drivers, BIOS, DDU, etc.). For this post, I'd like to focus only on the electrical side because some recent tests strongly suggest the issue could be related to electromagnetic interference.
My Hardware
Intel Core i5-12600 (replacement CPU received through Intel RMA)
NVIDIA RTX 5060 Ti
ASUS TUF Gaming B760M DDR4
32 GB DDR4 (2x16 GB)
WD Blue SN570 NVMe SSD
ASRock Challenger CL-650B 650W 80+ Bronze PSU
SuperFrame Vision 24" 180 Hz monitor
My power setup is:
Grounded wall outlet
iClamper Surge Protector (5 outlets)
PC + Monitor
The Problem
The input lag changes throughout the day.
Sometimes the game feels incredibly smooth and responsive, almost like everything is working perfectly.
Then, without restarting the PC or changing any settings, it suddenly becomes sluggish again. The mouse feels delayed, movement becomes less responsive, and it's much harder to make precise or fast plays.
Another symptom is that my wireless headset (USB dongle) occasionally experiences audio dropouts.
What I've Already Replaced
Over the course of this investigation, I've practically built a completely new computer.
I've replaced:
CPU
Motherboard
Graphics card
Power supply
RAM
SSD
Monitor
Mouse
Keyboard
DisplayPort cables
HDMI cable
Power cable
The issue remained essentially the same, which makes me believe this is very unlikely to be caused by faulty hardware.
Physical Tests That Actually Made a Difference
Grounding
The wall outlet was recently properly grounded.
Before grounding, touching the PC case would sometimes give me small electric shocks.
After grounding:
the electrical shocks disappeared completely;
the overall system behavior improved slightly.
Placing the PC on the Floor
This sounds strange, but placing the PC case directly on the floor noticeably improved the game.
Input response felt better, and even the monitor's image seemed slightly cleaner.
It wasn't a complete fix, but the improvement was easy to notice.
Separating the Cables
This was by far the most effective test.
Originally, my USB cables and DisplayPort cable were running very close to the PSU power cable.
I reorganized everything so that:
the AC power cable runs on one side;
the DisplayPort and USB cables run on the opposite side;
cables are no longer parallel;
if they must cross, they cross at roughly 90 degrees.
Result:
This produced the biggest improvement I've seen after months of troubleshooting.
I'd estimate the game is now 90-95% better than before.
Isolating the Power Cable
I also tested powering the PC using a different wall outlet, routing the power cable far away from all other cables.
This made virtually no difference.
Other Tests
I've also tested:
another monitor;
another DisplayPort cable;
HDMI;
another power cable;
every USB port (rear and front).
None of these solved the issue.
Another Strange Pattern
There's one very consistent behavior:
Late at night or early in the morning, the game almost always feels much smoother.
During the day, the problem usually becomes worse.
Another odd behavior is that sometimes the game suddenly becomes perfectly smooth for several minutes and then goes back to feeling sluggish again, without me touching anything.
What I'm Testing Next
I've already purchased two 9 mm clip-on ferrite cores.
I'll install:
one near the PSU connector;
one near the wall plug on the same power cable.
If that doesn't eliminate the remaining inconsistency, I'm considering installing an industrial EMI/RFI line filter (Schaffner, Corcom, or equivalent) before the iClamper surge protector.
My Question
Considering all these tests—especially the fact that simply separating the AC power cable from the USB and DisplayPort cables dramatically improved the issue—do you think this could actually be caused by conducted or radiated EMI/RFI?
Has anyone experienced something similar or knows of additional electrical tests I should perform?
I'd especially appreciate feedback from people with experience in:
EMC / EMI
Power quality
Electrical engineering
Industrial automation
Electronics design
Any ideas or suggestions would be greatly appreciated. Thank you!
Input Lag Varies Throughout the Day and Improved Significantly After Separating Power Cables. Could This Be EMI/Electric
miranda2026
