Page 1 of 6
⚡Potential fix for desync, input lag, floaty mouse, heavy car bug, etc.⚡
Posted: 24 Jul 2026, 01:20
by naporitan
naporitan wrote: ↑
26 Jul 2026, 14:14
Demonstration of the fix
https://www.hltv.org/player/26073/dan9armatura VS naporitan BLURBUSTERS
naporitan wrote: ↑
27 Jul 2026, 03:43
Also, I have the following connected to the motherboard: power supply, GPU, RAM, CPU air cooler, M2 SSD, headphones via mini jack, RJ45 internet, keyboard, mouse.
No more unnecessary RGB controller devices, etc.
A computer without a case is lying on a motherboard box
I start the computer with a screwdriver by closing the power_sw jumper
UPDATED: 27.07.2026
I noticed a long time ago that installing clean Windows fixes the desync, floating mouse, etc., and I managed to find out what actions cause a fierce desync.
The reason:
After installing the drivers on the motherboard and gpu, the system breaks down for some reason, and it is impossible to play games, it's just unpleasant, disgusting.
Possible fix (since all systems and builds are different):
Before installing Windows, you need to perform a full CMOS reset and then reset the BIOS settings to default.
Install clean Windows.
And you just need to update Windows through the Windows settings itself, as well as install all the "optional updates".
You do not need to install motherboard drivers from the manufacturer's official website or from the websites of hardware manufacturers like AMD, Intel, etc (the point is that the drivers should be installed from the microsoft server database and I know that there are outdated hardware that have not been supported for a very long time, in which case, unfortunately, you need to upgrade your hardware to a fresh one).
Do not use any tweaks on super mega low latency, do not touch anything in Nvidia Profile Inspector, etc.
Do not change the Windows power plan and disable mouse acceleration.
Nvidia's 3D settings are default; don't change anything there, I do not know the scaling, but I put a full-screen display without a check mark.
Some information about scaling - viewtopic.php?t=15406
Update all apps via the Microsoft Store, as it contains important system components.
BIOS:
In the BIOS, I only enabled Secure Boot on Standard before installing Windows.
System health test (theoretical):
Go to dino chrome com, set the difficulty to expert, and watch the dino. If it accelerates incredibly quickly, then there's something wrong with your PC. Perhaps the motherboard has crappy firmware, BIOS, crappy default BIOS settings, crappy drivers in the Microsoft server database, etc.
My score on expert difficulty: 5554
I could get even higher, but I'm really lazy. The point is, the dino's speed is static, and you can easily increase the score.
My recommendations:
Never change the firmware of the motherboard, GPU, mouse, keyboard, monitor, etc. After updating the firmware, the driver database on Microsoft servers is not updated, except in very rare cases, which is equivalent to a miracle.
Connect the mouse to the CPU port and the keyboard to the chipset port, and do not use USB headphones.
*https://youtu.be/IJYe98hq6rg?is=cVOZvuuG34eGGA9i Do this before installing a new system, as HWiNFO forces the HPET timer using the API, which can theoretically damage the system.
I was mistaken about Nvidia Reflex; this technology should be enabled wherever available, as it doesn't just reduce game latency but also synchronizes CPU and GPU operations.
There are games that don't support NVIDIA reflex, and in that case, you need to enable low latency mode on Ultra for a specific game in NVIDIA, but you don't need to enable this feature globally!
viewtopic.php?t=15646
*On a functioning system, NVIDIA Reflex technology works as intended by engineers.
*You also need to limit the frame rate through the game menu, you do not need to limit the frame rate through the NVIDIA panel, etc.
For example, for my 600 Hz monitor, I set the fps lock in CS 2 to 600
*For CS2, be sure to add the -allow_third_party_software parameter to the launch options.
My setup:
Asrock B650 PG Lightning
R7 7800X3D
*MSI RTX 3090 Suprim X 24GB
*For this GPU, you need to update the firmware for the resize bar to work and switch the toggle switch to gaming mode.
Windows 11 Home 25H2
The story of my gaming laptop:
Installing drivers on a laptop is very important. The laptop is based on an Intel Core i9 12900 processor, and everything works perfectly on it. The most interesting thing is that the Secure Boot setting is hidden in the BIOS.
The bottom line is that nothing breaks when installing drivers on this laptop, and it's nice to play games.
I use a translator and you can't help but understand what I wrote, and I apologize for that. If you don't understand something, then ask questions.
Samsung s25 fe
The dinosaur does not accelerate abnormally and it is possible to set records since the dinosaur's speed is static.
My pc
expert difficulty The dinosaur's speed is static and there is no abnormal acceleration
AEvCJPUfKdm84IOaWSEEo8nVtk9FHzaMtbhIXcoTF4SKdvVCFLgWxaoRE_XB8BDDOf0ICzGH95xP6p9B34qNXtbp.jpg
AEvCJPUfKdm84IOaWSEEo8nVtk9FHzaMtbhIXcoTF4SKdvVCFLgWxaoRE_XB8BDDOf0ICzGH95xP6p9B34qNXtbp.jpg (4.51 MiB) Viewed 3828 times
naporitan wrote: ↑
24 Jul 2026, 02:20
abnormal acceleration of a dinosaur on a faulty system
expert difficulty
My computer doesn't have abnormal acceleration. The dinosaur's speed is static. The dinosaur's difficulty is expert.
naporitan wrote: ↑
24 Jul 2026, 02:50
My computer has an offline version of Dino Chrome in the Chrome browser: chrome://dino/ The dinosaur's speed is static, there is no abnormal acceleration.
viewtopic.php?p=126429#p126437
Re: A possible fix or solution to the mystery of the problem
Posted: 24 Jul 2026, 01:47
by ablemor
If Windows was the problem, then why wasn't it good on Linux? + As far as I know, you blame the monitors for causing the problem, but in the end, is it a driver issue after all? + What do you mean by floaty mouse? Almost everyone means something different what I mean is that the mouse position always stops in a different place, it's never 1:1 sometimes I overshoot the target, sometimes I undershoot it.
By the way, couldn't this be caused by Windows hardware acceleration? The dino game, I mean?
Posted: 24 Jul 2026, 01:52
by naporitan
ablemor wrote: ↑
24 Jul 2026, 01:47
I'm far from an expert in software, etc., I'm a simple user, but Linux is for work tasks where the priority is on other tasks, not gaming. I know that there are Linux gaming solutions, but this is definitely not what we need. A floating mouse is a superficial explanation that mouse tracking is weird.
I might have been wrong about the monitors, but new monitors already have low resolutions pre-installed on BenQ and Asus, and Asus calls it esports mode.
Posted: 24 Jul 2026, 01:54
by naporitan
ablemor wrote: ↑
24 Jul 2026, 01:47
I have the stock browser settings and the default Windows settings as well. I don't use any tweaks. If something is wrong with your stock settings, then the system is faulty.
Posted: 24 Jul 2026, 02:11
by ablemor
The problem is that a lot of people have tried similar things reinstalling Windows, I even tried Linux, and the mouse was floaty there as well. If this were a Windows-related issue, the mouse should have felt different on Linux, but it didn't it felt similar. I couldn't flick, I couldn't land good shots despite having good reaction time. I dedicated a ton of money to solving this input lag problem: I had an (UPS), I bought an expensive power supply unit, an expensive motherboard.. I think interference is the issue in my case.
Posted: 24 Jul 2026, 02:20
by naporitan
ablemor wrote: ↑
24 Jul 2026, 02:11
expert difficulty
Posted: 24 Jul 2026, 02:41
by naporitan
ablemor wrote: ↑
24 Jul 2026, 02:11
Posted: 24 Jul 2026, 02:50
by naporitan
BIFFP9BOA_x5QoWLUrnKnAsjD3lUqztK9UvfH-NInhyTNW0mbYEJ6SWYRUG1Z-MJcRG0_z0KniTuk8YrjQioI6Cw.jpg
BIFFP9BOA_x5QoWLUrnKnAsjD3lUqztK9UvfH-NInhyTNW0mbYEJ6SWYRUG1Z-MJcRG0_z0KniTuk8YrjQioI6Cw.jpg (3.99 MiB) Viewed 3747 times
Posted: 24 Jul 2026, 03:07
by LaggyTyp
Interesting.
I’ve been complaining for years about having desync and hit-reg issues while gaming (e.g., in Battlefield). It’s not a network or internet issue; it’s a local problem that simply cannot be fixed.
I just tried out the Dino game, and I can clearly see it speeding up.
The interesting thing is: when I play BF6, the game runs normally at first, but minute by minute, the opponents get faster and faster. I barely have any time left to react. My window for reaction shrinks. The worst gamers in the world start playing like pros.
The Dino game fits this pattern (the problem) perfectly.
Posted: 24 Jul 2026, 14:35
by ablemor
try to play in fullscreen windowed mode
