SELF GROUNDING OUTLETS CAUSE HEAVY MOUSE
chipotlechicken
Hello, I've come to the conclusion after many years of testing that self grounding outlets ruin your games. Here's the cavait. The self grounding outlet should only be used when you have a METAL electrical box. I live in the west coast of canada, fairly new townhouse build. Every single outlet in the livng areas has a PLASTIC BOX. But there are self grounding outlets. I changed them all to regular grounding which is cheaper and no more heavy mouse
adelsa123
Re: SELF GROUNDING OUTLETS CAUSE HEAVY MOUSE
WHAT DO U MEAN U switched to regular grounding can please explain ! for example me i dont have grounding at my room so i did a dedicated rode to my room outlet i did ground the outlet running a wire from the ground to the outlet ! but still no improvementchipotlechicken wrote: β02 Aug 2026, 03:52Hello, I've come to the conclusion after many years of testing that self grounding outlets ruin your games. Here's the cavait. The self grounding outlet should only be used when you have a METAL electrical box. I live in the west coast of canada, fairly new townhouse build. Every single outlet in the livng areas has a PLASTIC BOX. But there are self grounding outlets. I changed them all to regular grounding which is cheaper and no more heavy mouse
chipotlechicken
Here are two different outlets. Regular and self grounding.
This one is regular: https://leviton.com/products/t5325-w
This one is self grounding: https://leviton.com/products/16252-w
The self grouding one has a copper plate on one of the ends, thats how you know its self grounding. That little plate connects to a METAL box and works as grounding.
The issue is when you're using these self grounding outlets in a PLASTIC BOX.
DudeBeFishing
I don't know how you came to that conclusion. The installation is electrically the same between these outlet types when installed in a plastic box. Black wire to gold screw. White wire to silver screw. Green/Bare wire to green screw. If there's no ground wire, both won't be grounded.
The non self grounded outlets might cause issues if installed in a metal box without a ground wire, because it then won't have a working ground. Technically by code, you can use the metal conduit and metal box as your ground, and only run 2 wires (hot and neutral) to the outlet.I recommend running a separate ground wire to avoid grounding issues. It's also required by some local building code.
