Acer Predator XB273U F5 and Custom resolution
nuninho1980
Post by nuninho1980 » 06 Aug 2026, 16:53
Hello. I can't enter "custom resolution" for grey out on NVCP... Because v610.88 driver blocks custom, ok?
Therefore, I can't work 50Hz. I'll try to downgrade firmware to 1.1.4 or 1.1.6...
NOTE: G-SYNC is disabled. Lastest firmware of monitor is 1.1.8. DP port using
Best regards.
RAM: 2x16GB DDR4@3600MHz
MB: MSI PRO Z690-A DDR4
GPU: Zotac RTX 4090 non-OC <3 :D
HDD: SATA 1TB
PSU: AEROCOOL 1kW 80+ Gold
Disly: ACER Predator XB273U F5 !NEW! :mrgreen:
nuninho1980
Re: Acer Predator XB273U F5 and Custom resolution
Post by nuninho1980 » 07 Aug 2026, 09:12
How do we decrease minimum Pulsar low fps on OSD from 75 as default to 48??
HDD: SATA 1TB
nuninho1980
Post by nuninho1980 » 08 Aug 2026, 04:52
@brownvim: Please help.
HDD: SATA 1TB
nuninho1980
Post by nuninho1980 » 08 Aug 2026, 14:31
I find DSC-enabled problem. This causes to block "customize". RTX 4090 needs DSC for 2560x1440@360Hz due to the lack of DP 2.1b. Therefore, I will change cable from DP 1.4 to new HDMI 2.1 for access to customize.
-- But how do we enable strobe for 50Hz?
HDD: SATA 1TB
nuninho1980
Post by nuninho1980 » 28 Sep 2026, 09:59
nuninho1980 wrote: ↑
08 Aug 2026, 14:31
By drG-SYNC - https://www.nvidia.com/en-us/geforce/fo ... r/3624862/
!!SOLVED!! by me (@ricardonuno_) - https://www.nvidia.com/en-us/geforce/fo ... r/3624899/ :D
HDD: SATA 1TB
