In some local pc website I found test claiming that for new graphic cards with only digital connections - without direct vga d-sub connection, there is added significant input lag when using crt monitor by d-sub adapter in gfx card. Whatmore they show that faster lcd (120-144hz, they tested Benq z model) show smaller input lag than crt by d-sub adapter.
Is it true?
edit: sorry, input lag category would better suit this topic..
edit2: http://pclab.pl/art59113.html (Q83Ia7ta was faster)
Adapter d-sub input lag
Alamar
flood
Re: Adapter d-sub input lag
post the link?
it depends on the implementation of the dac. it could be laggy or not laggy
Q83Ia7ta
http://pclab.pl/art59113-2.htmlflood wrote:post the link?
flood
comparing clocks at the center of the screen is not a valid way to precisely measuring input lag if the outputs are not sync'd (which is rarely the case).
here's a quite technical article concerning this stuff
http://www.prad.de/en/monitore/specials ... art17.html
