I’m having a weird issue with my LG 27GX790A-B and RTX 5060 Ti and wanted to see if anyone here has run into the same thing.
GPU-Z is showing:
Current Link Rate: 10.0 Gbps
Max Link Rate: 10.0 Gbps
Lane Count: 4
So it looks like the monitor is only running at UHBR10 / 40 Gbps instead of UHBR13.5 / 54 Gbps.
I’m running 2560x1440 at 480 Hz, 8-bit RGB. G-SYNC is off, Windows HDR is off, and DAS is on.
Right now I’m using a 6.6 ft IVANKY DP80 cable that is supposedly VESA certified:
https://www.amazon.com/dp/B0F6LJ5Q6R
I also ordered a shorter 3.3 ft Silkland DP80 cable that should arrive later today:
https://www.amazon.com/dp/B0DQ7F64L5
I’ve updated to the latest NVIDIA driver, checked MSI’s support page and don’t see any VBIOS/firmware update for the card, and the GPU otherwise seems to be working normally.
I also ordered the USB-A to USB-B cable for the monitor so I can check LG Switch for any monitor firmware updates.
Is this a known issue with this monitor and RTX 50-series cards, or does it sound like something specific to my setup?
If anyone has this monitor with a 50-series GPU, what link rate does GPU-Z show for you? And if you were stuck at 10.0 Gbps, was there anything that fixed it?
I'm hoping to run the monitor without needing DSC.
LG 27GX790A-B stuck at 10 Gbps/lane with RTX 5060 Ti - should it be 13.5?
Shade7
- kyube
Re: LG 27GX790A-B stuck at 10 Gbps/lane with RTX 5060 Ti - should it be 13.5?
It requires a registry edit.
Piotrek wrote: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4d36e968-e325-11ce-bfc1-08002be10318}\0000
DP2X_IGNORE_CABLE_ID_CAPS 1
to fix uhbr on nvidia gpus
Shade7
Really? That's it?
I'll try that as soon as I get home.
What is the highest 4:3 resolution you think I could use at 480Hz without triggering DSC?
