RX6500XT unable to run two 4K 120/144Hz monitors
kwas71
Post by kwas71 » 14 Sep 2026, 14:22
Hello everyone,
My iGPU (X870E MAG Tomahawk + Ryzen 9950X3D) didn't want to support both monitors at their highest refresh rates, so I bought a RX6500XT.
I only want simple video output, no gaming, and the monitors are used with a Linux workstation:
- BenQ RD280UG (3840x2560 120Hz, ports: HDMI 2.1, DP 1.4, USB-C)
- LG 27GR93U (3840x2160 144Hz, ports: HDMI 2.1, DP 1.4)
I connected the BenQ via HDMI 2.1 and the LG via DP 1.4 (DSC).
The problem is that the RX6500XT doesn't seem to support them either.
When the LG is already running at 3840x2160@144Hz, the BenQ has no output and enabling it with xrandr at any resolution gives me the error "xrandr: Configure crtc 0 failed".
Now I understand that the RX6500XT could potentially be not the right fit for this setup. In case I won't manage to make it work, I can return it, but I would kindly ask you for an alternative. I prefer not to spend a lot of money on a GPU just because it performs well at gaming, I will be satisfied if I get video output on Linux, do some coding and nothing visually demanding.
Thanks!
Dalek
Re: RX6500XT unable to run two 4K 120/144Hz monitors
Post by Dalek » 16 Sep 2026, 14:57
Could you also specify which RX6500XT you have? is it ASUS or MSI?
They should in be able to support up to two displays at the same time, one thing I did find on MSI's site is that it says: 'Supports 4K@120Hz', not 144hz, so that's something to look out for.
Some quick troubleshooting steps I'd try:
1. Try using Windows and see if the same issue occurs there to rule out if it's the GPU or Linux (drivers) acting up.
2. Try an integrated GPU for the second monitor whilst one monitor is connected to the GPU, this might be a potential workaround, but you might be limited to 60 or 120hz.
3. Try running your LG monitor at 60hz, does it then let the other monitor connect? if so, try then switching to 120hz.
4. Stick with 60hz instead for both monitors, not ideal since you wanted a higher refresh rate for both of them.
5. Try installing different drivers if possible (from memory, you can install different versions of software via command line for some distros, but I am not familiar with installing GPU drivers for Linux)
Hope this helps!
kwas71
Post by kwas71 » 17 Sep 2026, 06:41
It is the Gigabyte RX6500XT.
1. I tried Windows, still the same, only BenQ plugged in works at 3840x2560@120Hz, as soon as I plug in the LG, it gets down to 3840x2160@120Hz.
2. That could work but again I hope I can either get it running on this GPU or return it for something else
3. Yes, it does connect, but then it becomes a combination game in driving either lower resolution or lower refresh rate on either of both monitors. For example, BenQ being at 3840x2560@120Hz, then I plug in the LG and the BenQ immediately switches to 3840x2160@120Hz. If I then try to manually set it, the other monitor gets a lower resolution/lower refresh rate, or the current monitor forces it, depends. Basically, there is no sane way to make it work.
4. Yeah exactly, it does work, but then why pay for something extra and then not use it :P
5. With Windows not working I think we can rule out it's the Linux driver
Btw, I am convinced that I have the right cables to power the monitors. I tested two DP cables and two HDMI cables, both shipped with BenQ or LG, so these cable are made to work with that caliber of screens. Again, driving just one of these screens is completely fine, but having two work at the same time is impossible.
I'm thinking of buying the Intel A310 or A380 but I'd like to be 100% sure it will work.
Dalek
Post by Dalek » 20 Sep 2026, 03:58
Sounds like bandwidth limitation then.
Having looked into this further, I honestly don't know what the cheapest graphics card would be in order to run dual 4K monitors at higher refresh rates. Most sites will mention maximum resolution (somewhere around 8K) at 60hz and not triple digit refresh rates.
I guess if money is the concern, try an A380 first, if that doesn't do it then I'd try getting the most powerful graphics card from AMD like a 9070XT.
