RX6500XT unable to run two 4K 120/144Hz monitors
Posted: 14 Sep 2026, 14:22
Hello everyone,
My iGPU (X870E MAG Tomahawk + Ryzen 9950X3D) didn't want to support both monitors at their highest refresh rates, so I bought a RX6500XT.
I only want simple video output, no gaming, and the monitors are used with a Linux workstation:
- BenQ RD280UG (3840x2560 120Hz, ports: HDMI 2.1, DP 1.4, USB-C)
- LG 27GR93U (3840x2160 144Hz, ports: HDMI 2.1, DP 1.4)
I connected the BenQ via HDMI 2.1 and the LG via DP 1.4 (DSC).
The problem is that the RX6500XT doesn't seem to support them either.
When the LG is already running at 3840x2160@144Hz, the BenQ has no output and enabling it with xrandr at any resolution gives me the error "xrandr: Configure crtc 0 failed".
Now I understand that the RX6500XT could potentially be not the right fit for this setup. In case I won't manage to make it work, I can return it, but I would kindly ask you for an alternative. I prefer not to spend a lot of money on a GPU just because it performs well at gaming, I will be satisfied if I get video output on Linux, do some coding and nothing visually demanding.
Thanks!
Thanks!
