Are you sure that what you’re trying to find actually exists?
Monzy
Post by Monzy » Yesterday, 05:38
Hello everyone.
Before you read everything I’ve written below, I want to make it clear that I’m not new to this topic. I’ve been struggling with input lag and that sluggish, muddy feeling in games (both online and offline) for four years now.
My main issue is the feeling that my monitor is running at a lower refresh rate than it actually is, along with textures becoming blurry during sudden movements, which eventually causes me to lose focus.
Based on what I’m about to write, you can draw your own conclusions: either I’ve completely lost my mind and will soon meet God (what’s up, Marv1n?), or maybe there’s actually some truth to what I’m saying. It’s up to you, guys.
First of all, I want to repeat something: I’m not saying that all of you guys here are crazy or anything like that. It’s just that, like many of you, I’ve driven myself into a corner. I can’t seem to find even the slightest solution to this problem — at least not one that lasts longer than a single day.
So, here’s my thought:
What if we looked at input lag from a psychosomatic perspective?
Didn’t get it? Let me use myself as an example.
I wake up, sit down at my PC, launch a DM server, and see that I’m getting 500 FPS, but I just don’t feel the smoothness you’d expect from 240Hz.
What do I do next?
Exactly. I start tweaking absolutely everything on my PC, digging through every setting over and over again, desperately trying to figure out the reason behind this weird, muddy feeling on my screen.
After 2–3 hours, something catches my attention. I think: “THAT’S IT! THIS IS THE SOLUTION! I’ll try this, and maybe it’ll finally go away. Maybe everything will feel right again. Maybe I’ll finally be able to frag like I did back in 2018!”
At that moment, your brain releases dopamine in anticipation of something positive.
It’s similar to gambling addiction. Gamblers don’t necessarily get pleasure from watching the roulette wheel spin. They get excited by the possibility that the next spin might land on 10x and they’ll win a lot of money.
And that’s exactly where I’m going with this.
We’re in a similar situation. We think we’ve finally found a solution, and suddenly we have hope that it’ll actually work.
That combination of anticipation and dopamine makes you consciously start paying attention to how smooth the game feels. Your brain actively looks for confirmation that things have gotten “better.”
And then comes the first game. You drop 25 kills and think: “THAT’S IT! Either I’ve finally fixed the entire problem, or at least I’ve found something that will work for a couple of hours.”
But have you ever stopped to think about how you actually managed to get those 25 kills?
I’ll tell you: confidence.
You made some changes, and you got those 25 kills because you simply stopped doubting your decisions and actions. You entered a state of flow.
On top of that, there’s another factor: reduced anxiety.
When you spend so much time constantly thinking that something is wrong, that your game feels sluggish, that everything feels heavy, etc., your brain ends up dedicating an excessive amount of attention to this perceived “input lag.”
I’m 100% certain that input lag exists. But I’m not so sure about how significant it actually is compared to how much we make it out to be.
What if we’re simply examining every single pixel too closely, desperately searching for a needle in a haystack when there might not even be a needle there in the first place?
I’d really appreciate your thoughts and opinions on this.
I genuinely feel like I’m going insane… :twisted:
soul4kills
Re: Are you sure that what you’re trying to find actually exists?
Post by soul4kills » Yesterday, 22:16
Input lag is a cpu problem. Very simple idea and concept. But because the majority of people here lack the understanding of how computers work, they often find some other unrelated reason to explain it.
Do you have a high performance CPU or low performance? How much work can your cpu complete in a given amount of time. If you have too many devices/drivers/apps running, then that means theres more work the cpu has to do before it can service your game. It's honestly that simple. People that try to push for higher framerates fall into the trap of more frames = lower frametimes = lower input latency. But they don't realize they are adding more work for the CPU to do and it can't complete it fast enough. And they always seem mystified by why they still getting input lag. Even more so than people that run lower fps setups.
Very simple fix to input lag is reduce your CPU's workload = lower input latency. It's really that simple. This forum is full of delusional people that think they know what they're doing but they honestly don't.
Monzy
Post by Monzy » Today, 00:09
Sometimes I feel like some of these people are actually losing their minds. And in my attempt to find a solution, I end up following them down the same rabbit hole.
Yesterday, I made up my mind that I'm simply going to install Windows 26H2, make it as comfortable as possible for my needs, and stop worrying about everything else.
Because I've come to realize that my problem probably isn't abnormal input latency, but rather what's going on in my head. The funniest part is that I can't even stick to one specific sensitivity for a single day. I'm constantly changing it, thinking that it's the problem. When in reality, I should just get rid of all that unnecessary noise and focus on my opponents' behavior in-game and how to position my crosshair.
I feel like some people have either set unrealistic expectations for themselves or spent too much time watching things they probably shouldn't have.
MontyTheAverage
Post by MontyTheAverage » Today, 05:56
Monzy wrote: ↑
Yesterday, 05:38
Hello everyone.
What do I do next?
Stop gaslighting yourself and others. It's not placebo. It is 100% real. You can see and feel the difference in mouse feel. hitreg, incoming damage, smoothness, floatyness and sluggishness of aim/mouse. You can 100 percent can tell the states of good state and bad state. And also reflects it when the issues go away or becomes minimal with the scores.
Stop spreading "it's in your head" claims. Maybe it is for you and some, but then you do not have the real issues lot of ones here have. And yes there is an element of mental things that can play into your performance but you can easily distinguish between playing bad because of your own problems versus the lag issues. You don't just magically go from playing like a noob to beaming people like a pro without much effort on top of the difference you physically feel between the good and bad state because of some "anxiety" or "confidence" nd without some external issues causing it. C'mon man. Stop spreading this "in your mind" nonsense when it comes to the lag issues that so many here suffer from where the symptoms are so similar.
simon
Post by simon » Today, 06:27
This theory is a good attempt to make sense of something that doesn't make sense. Trying to put together the bigger picture is rare here I'd say.
I don't agree that this issue doesn't exist at all except in our heads though. I can show you what happened yesterday after simply replugging wall sockets.
https://ibb.co/TDK3W9Py
According to your theory I am actually that skilled and managed to get my head right by simply believing in something. I disagree.
But unlike many others here who think they're skilled and the desync issue is keeping them back, I say it's neither the skill nor the belief that got me banned. I say it's the unfair advantage that allowed me to play like that and eventually some anticheat flagged it as "irregular" lol. This is the best proof imo that there is never any fairness in any game.
Think about it - what do your opponents see when you get that "supersynced" game. You become unhitable, fast, your bullets go straight like a laser. As opposed to desynced game where everything is the opposite. I'd say neither is fair.
I'd put the possible levels of this issue into 3 categories: 1. completely desynced and unplayable 2. the average kind of boring that gets you through games 3. the supersync where you literally drop em like flies and eventually get banned.
I've experienced all of those on different hardware, different places and from 4g to fibre.
The fact that the same "fix" doesn't work every time and is never permanent leaves a huge clue.
But understanding this point of view requires one to see past their own nose and their own issue. It would mean that from a certain point skill becomes irrelevant and all that matters is if you get the advantage or you get the crap.
You acknowledge that "the issue" is still real and present even when your game runs like god's game.
And lastly this theory will stand the test of time. Everything that happens or I find out only confirms it to be true. I'm not invested in throwing around one-liner fixes that age like milk. The description of this issue dates back to at least CS 1.6 times and I think it's time to look at it from a different perspective by bringing new ideas that have never been said before.
Monzy
Post by Monzy » Today, 07:12
Yes, I understand what you're talking about. Back in February, I experienced some kind of absolutely insane improvement in my gameplay. I jumped from 2,200 ELO to a peak of 2,800...
I was literally just running around and killing everything I saw. My personal best stats were 22 AVG, 104 ADR, 0.97 KR, and 1.5 KD.
This went on for about a month or so, and then... then it was over.
I went back to playing like garbage, and now I'm sitting at 2,500 ELO with below-average stats.
And I have absolutely no fucking explanation for what happened. The only explanation I can think of is what I mentioned in my original post. I simply started grinding Kovaak's, settled on one sensitivity, and didn't touch it for two weeks.
Maybe I just don't experience input lag and its symptoms as severely as some people here. Maybe my game runs well enough to be playable... I honestly don't know.
But this issue definitely exists, and no matter how many different things I've tried, every solution has only worked for a couple of hours or days.
Sorry if I didn't express my position on this issue very clearly.
astroasis
Post by astroasis » Today, 15:32
Yeah I wish it were a mental issue also.
soul4kills
Post by soul4kills » 51 minutes ago
And would you look at that, 2 new posts about high FPS but terrible latency and stutter. It's almost like pushing your FPS too high might be the problem. No no no, gotta be something else.
