Best latency setup at 500Hz? (Reflex 428 cap vs VRR vs Fixed Refresh)
NocturnalFPS
Post by NocturnalFPS » Today, 14:11
Hey everyone,
I'm running an RTX 5080 with a 500Hz OLED monitor, mainly playing CS2 and Valorant (where my FPS easily stays above 500-600+). I'm trying to figure out the best overall setup for lowest input latency and best frame pacing.
I know when you run G-SYNC ON + NVCP V-SYNC ON + Reflex On + Boost, Reflex automatically caps the framerate to ~428 FPS at 500Hz.
Given my setup, which of these options makes the most sense?
1. G-SYNC ON + NVCP V-SYNC ON + Reflex On + Boost (letting Reflex auto-cap at ~428 FPS)
2. G-SYNC ON + NVCP V-SYNC OFF + Reflex On + Boost + manual cap at 493-497 (via in-game limiter or RTSS)
3. G-SYNC ON + V-SYNC OFF + Reflex On + Boost + uncapped FPS (so G-SYNC only engages if FPS dips below 500)
4. Fixed Refresh Rate (G-SYNC OFF, V-SYNC OFF) + Reflex On + Boost + capped at 600 FPS (via in-game limiter or RTSS)
Is the 428 FPS Reflex auto-cap worth it for tear-free consistency, or am I giving up too much latency/clarity compared to capping around 495 or just running Fixed Refresh at 600 FPS?
Thanks in advance!
