Stuttometer - open-source Windows ETW stutter & frame-pacing diagnostic tool (looking for VRR / NVIDIA / Intel testers)
drop
Post by drop » 55 minutes ago
Hey everyone,
I've been working on an open-source tool called Stuttometer (C++/Win32, GPLv3) to help track down micro-stutters and frame-pacing hitches on Windows without having to manually record and dig through giant .etl files.
Tools like PresentMon and CapFrameX are great at showing when a stutter happened, and LatencyMon/WPR show system activity, so the goal here was to combine that into something you can just leave running in the background (~48 MB RAM, <0.3% CPU, zero heap allocations on the ETW hot path).
When it catches a frametime spike, cadence judder, DWM compositor glitch, or audio dropout, it grabs a ~280 ms window around the hitch and correlates kernel + user ETW events (D3D12 shader/PSO compilation, driver DPC/ISR spikes like nvlddmkm.sys or amdkmdag.sys, VRAM paging, disk I/O, context switches, and SMI stalls). It also scales thresholds to your monitor's refresh rate and tries to filter out obvious loading screens and long pauses (>= 2s) so they don't skew your session stats.
Note on Admin rights: It asks for Administrator access because Windows requires it to open a kernel ETW session. There's no DLL injection, no reading game memory, no anti-cheat hooks, and no background network telemetry.
I'm a solo dev testing on one machine (AMD GPU + 200Hz/60Hz non-VRR dual monitor), so I'm trying to get feedback from people on NVIDIA, Intel Arc, VRR (G-Sync / FreeSync), high-Hz OLEDs, etc.
If you want to try it:
  1. Grab the latest release on GitHub (search xdr0p/stuttometer or go to github.com/xdr0p/stuttometer/releases).
  2. Run stuttometer_gui.exe while playing.
  3. If it misses a hitch you felt, attributes the wrong cause, or logs any ETW warnings (or flags an obvious loading screen), hit Export JSON (turn on Redact in Settings if you want your username/paths scrubbed) and drop the .json file in a GitHub Issue with what was happening on screen.
