Maximum Pre-rendered Frames and how it works
Kirayamato
Post by Kirayamato » 11 Jan 2014, 08:36
hi guys as you may know there is a setting in nvidias control panel Maximum pre-rendered frames i want to know how it works and i have it set to 1 right now does this have any correlation to ur monitors display example if i am on a 144 hz monitor should i have atleast 145 fps to have atleast one pre rendered frames (just an example) just wanna know how it works and how it effects input lag
SS4
Re: Maximum Pre-rendered Frames and how it works
Post by SS4 » 11 Jan 2014, 08:55
Check that topic:
http://forums.blurbusters.com/viewtopic.php?f=2&t=98
The information you are looking for might be in there somewhere iirc
Post by Chief Blur Buster » 11 Jan 2014, 10:21
It's a very similar topic, but the "Maximum prerendered frames" is different -- I'd love to hear sharknices' comments on this one.
nimbulan
Post by nimbulan » 11 Jan 2014, 14:59
From what I understand, pre-rendered frames is the number of frames-worth of information the CPU can calculate ahead of the video card, basically letting game logic run ahead of the display. When set higher than 1, the game can queue up multiple frames for rendering, causing input lag and potentially stuttering. The setting is meant to smooth out gameplay when frame times are highly variable and you turn pre-rendered frames up, but in practice it seems to have the opposite effect. The actual effect varies per game, though you will see a substantial benefit in some by turning it down. I know Guild Wars 2 has some pretty significant input lag with vsync on if this setting is higher than 1.
Basically, keep it at 1. If you have abnormal stuttering problems in a specific game, you can try turning it up and see if there's any change.
Chickenfeed
Post by Chickenfeed » 12 Jan 2014, 17:34
It is worth noting, to work efficiently, SLI requires this be left untouched, downwards anyways (which is the default of 3)
Feedanator 6.0
CASE:FT02B|PSU:AX850|CPU:i7 4770K|Mobo:Z87 Pro|Ram:8x2GB GSkill 2400|GPU:SLI GTX 780 3GB|HD:M4 128GB+256GB/F1 1TB|SOUND:Titanium HD,PC350|LCD:VG248QE/QH270-lite|OS:Win8 x64 Pro|INPUT:SS Sensei /w HD9/DasUltSilent|COOLING:H80
sharknice
Post by sharknice » 13 Jan 2014, 00:55
Chickenfeed wrote:It is worth noting, to work efficiently, SLI requires this be left untouched, downwards anyways (which is the default of 3)
I use SLI and it won't let me set anything other than "Use the 3D application setting" on mine. So I'm assuming it is up to the game on how to handle it. If I had a choice I would set it to 1. Most games I play are CPU bottlenecked anyways. I think anything higher than 1 would add quite a bit of input lag.
Chickenfeed
Post by Chickenfeed » 13 Jan 2014, 03:35
You can override it in NV Inspector. For all around compatibility's sake NV disable altering it via their CP.
2 can work with 2 way SLI but 1 will starve the gpus for information and thusly cripple performance in many cases. 3 and 4 way configs are even more reliant on a deeper setting to perform to their potential.
For older/less demanding stuff where SLI is overkill, I diable it per game profile and set it to 1.
Feedanator 6.0
Q83Ia7ta
Post by Q83Ia7ta » 14 Jan 2014, 06:03
Chief Blur Buster wrote:It's a very similar topic, but the "Maximum prerendered frames" is different -- I'd love to hear sharknices' comments on this one.
Maximum Pre-rendered Frames is directx option
Maximum prerendered frames is opengl option
Nvidia Control Panel let you set only "Maximum Pre-rendered Frames" and after that same value set to "Maximum prerendered frames". Checked with NVIDIA Inspector.
Post by RealNC » 14 Jan 2014, 07:56
Here's a suggestion for the Chief: do an article about input lag with SLI vs single GPU :-)
JakeNQuake
Post by JakeNQuake » 14 Jan 2014, 15:49
RealNC wrote:Here's a suggestion for the Chief: do an article about input lag with SLI vs single GPU :-)
+1 would love to know more about that topic.
