So far there has been many problems like all the blacks are very bright and grayish + there is very annoying ghosting (or crosstalk?) while playing some games like Diablo3. The game actually looks better without the blur reduction, but it's a pain to always adjust the settings as the brightness goes up huge amounts when disabling the blur reduction.
Anyway, I've tried to use the VT trick but having an AMD card I've needed to use the toasty's app for it. I can't really see any difference with the VT enabled or using the "normal" resolution.
I'm asking you people, is this really the best this monitor can offer when Blur Reduction is on and VT trick applied at 1080p@ 120Hz? Override is on, Persistence is at 2ms and Crosstalk is at zero. AMA is HIGH, Instant Mode is ON
Any input and tips would be really welcome.
PS. Is there a way way to make a different settings for Blur Reduction and certain brightness vs. Blur Reduction off and different brightness that I could change via couple of inputs on the monitor's buttons, not having to need to browse all the sub directories and such? Also I haven't figured out how to load those settings I've saved in "Gamer1" etc. If I browse the different Picture modes from the menu and choose Gamer1 it's nothing like when I saved it...
Thanks.
