Just found out today (December 3rd) thanks to IxAMxANGEL on Twitter.
New BENQ XL2411Z monitors directly from BENQ's factory very close to the 200 bux number! And better "LightBoost"! These are the latest Version 3 firmware, and Blur Busters Strobe Utility compatible!
1. Click BENQ XL2411Z
2. Then click "Buy Now"
3. Then enter this coupon code: benqlegacy%15
4. Price reduces to $211.65!
Other good deals going on now at BENQ:
BENQ XL2411Z - $211 after discount - 24" 144Hz gaming monitor with BENQ Blur Reduction and LightBoost
BENQ XL2420Z - $339 after discount - Same as XL2411Z, fancy stand w/carrying handle, more inputs, remote
BENQ XL2720Z - $449 after discount - Bigger 27" version of XL2420Z
BENQ XL2411Z -- only $211 direct from BENQ !!!!!!!
Re: BENQ XL2411Z -- only $211 direct from BENQ !!!!!!!
hm... benqlegacy%15
are they replacing the xl2411z with a new model?
Falkentyne
A benq rep replied on a forum (I don't remember where) and said that the 2411Z was end of life, and they are replaced by the 2420Z, 2420G and 2430T.
This is true!Falkentyne wrote:A benq rep replied on a forum (I don't remember where) and said that the 2411Z was end of life, and they are replaced by the 2420Z, 2420G and 2430T.
That said, the XL2411Z and XL2420Z uses the same panel, wih exactly the same picture quality and benefits.
The advantages of the XL2420Z is a fancier case, carrying handle, more inputs, and the S-switch remote controller. But there is no difference in the panel aspects, if you are looking to save bucks. Good for those on budgets who couldn't justify a 120Hz monitor. The panel is the same!
With this discount, is this the best value for money option? BENQ XL2411Z
