BenQ XL2411Z V2 Best settings
Berkel
Post by Berkel » 15 Dec 2014, 14:01
Hi everyone i need the best settings for csgo:
144 or 120hz?
Brigthness-
Contrast-
Low Blue Light-
Blur Reduction-I play without cuz i need 1ms input lag
Color Temperature-
AMA-
Instant Mode-
Sharpness-
Gamma-
Thank you for helping me :)
kamill
Re: BenQ XL2411Z V2 Best settings
Post by kamill » 15 Dec 2014, 14:09
If you play without blur reduction, use 144Hz. Try FPS2 setting.
Berkel
Post by Berkel » 15 Dec 2014, 14:21
Ty, but i need settings in standard mode :).
Falkentyne
Post by Falkentyne » 15 Dec 2014, 21:28
You don't and can NOT have 1ms input lag.
You already have 1 ms input lag on your mouse and that's under best case scenario.
There is a difference between RESPONSE TIME and INPUT LAG. You're probably mixing the two.
The monitor has an average response time of 4.5ms.
Average input lag is 10 ms.
You can verify that from two different reviews.
http://www.displaylag.com/benq-xl2720z- ... g-monitor/
and
http://www.digitalversus.com/lcd-monito ... /test.html
Instant mode on:
Top: 2.6ms
Middle: 10.0ms
Bottom: 17.5ms
These are the input lag values when Instant Mode and Blur Reduction are enabled:
Top: 6.7ms
Middle: 15.0ms
Bottom: 23.3ms
And the second review:
The input lag is excellent at just 10 ms, which will go totally unnoticed when gaming—even with high-level gaming.
So no you won't have 1 ms input lag on ANY screen that isn't a CRT. Sorry.
So go ahead and enable the blur reduction. You are not going to tell a difference between 10ms and 15ms from the monitor, ESPECIALLY with vsync off. I suspect the above numbers are with vsync on, but not sure. I do know that 144hz+blur reduction+vsync off feels like I'm using my brain to move around instead of my mouse. It's that fast.
Post by Chief Blur Buster » 15 Dec 2014, 22:01
Falkentyne wrote: Instant mode on:
Top: 2.6ms
Middle: 10.0ms
Bottom: 17.5ms
Top: 6.7ms
Middle: 15.0ms
Bottom: 23.3ms
As a caveat, these are measurements made at 60Hz.
For lag at 120Hz, approximately halve the middle/bottom values for instant mode.
Also, the strobed numbers are incorrect, since it was measured using double-strobe at 60Hz, which is inaccurate. Discard the second set of numbers.
Falkentyne
Post by Falkentyne » 15 Dec 2014, 22:49
mm 5 ms.
Ok that makes more sense.
Was actually wondering why the monitor seemed to feel more responsive than those numbers showed. Thanks chief.
But yeah, enable the blur reduction. Really no reason to not have it on, except for the lower brightness possibly stopping the colors from being sharp enough. I find 1ms persistence to be easy on the eyes while still being bright enough to be pleasant (1ms with blur reduction on is close to 20% brightness with BBR off).
Berkel
Post by Berkel » 16 Dec 2014, 07:38
Ty, but i need
Brigthness-
Contrast-
Low Blue Light-
Color Temperature-
AMA-
Instant Mode-
Sharpness-
Gamma-
masterotaku
Post by masterotaku » 16 Dec 2014, 11:51
Berkel wrote:Ty, but i need
Brigthness- 100
Contrast- 40
Low Blue Light- 0
Color Temperature- 100, 100, 100 (I'm colorblind and this could be different in every monitor)
AMA- High
Instant Mode- On
Sharpness- 5
Gamma- 5
And Blur Reduction On.
That's what I use, but I had to make an ICC profile to use an even "darker" gamma than Gamma 5.
Monitor: Asus PG278QR
Falkentyne
Post by Falkentyne » 16 Dec 2014, 13:59
You know that you cant 'ask' for the best settings for CS:Go because everyone is going to have different preferences.
There's actually a CS:Go profile on benq's site (it replaces FPS2 with a custom preset) but frankly, if you're playing that game to shoot people and win, you may want FPS1 preset (not standard), black eq=20,colors 100/98/96 or 100/100/92 and blur reduction on.
This way you can see people in dark areas and sometimes see things through smoke.
If you are using 1920x1080 native res, VT tweaks are fine (But can't use VT tweaks at 144hz)
If you are NOT playing at 1920x1080 (native resolution) then you can try not using 144hz refresh rate, to unlock the "display mode" aspect tweaks (display mode settings don't work at 144hz, and are buggy/incorrect with VT tweaks):
Use 120hz, DISABLE Vertical total tweaks for 120hz and then use the monitor "display mode" aspect ratios to either get black bars to left and right (aspect setting in the OSD) or centered and scaled to a different monitor size, like 4 :3, 5:4, 16:10, etc:
(these settings don't work correctly when using Vertical total tweaks).
