Best setup for csgo on a benq xl2430t motion blur reduction
BlackJesus
Post by BlackJesus » 21 Dec 2014, 17:26
Should i have motion blue reduction on or off apparently the v2 of motion blur reduction has less input lag i dont know if this is true and how can i make the screen brighter on the motion blur reduction mode thank you
Falkentyne
Re: Best setup for csgo on a benq xl2430t motion blur reduct
Post by Falkentyne » 21 Dec 2014, 20:13
It's the same as the Z series blur reduction.
The only difference is strobe phase no longer defaults to 100 (I guess they realized people like VT tweaks), strobe phase and strobe duty are now adjustable in the OSD, without needing the service menu (Area and Intensity), even though the service menu is still there with the same options (you can enable single strobe for 60-75hz there), and lightboost has been removed and extra color and display tweaks have been added.
BlackJesus
Post by BlackJesus » 21 Dec 2014, 21:01
so yes or no will it give me and advantage
Falkentyne
Post by Falkentyne » 21 Dec 2014, 21:53
Try it and find out? Why are you asking me ? I can't tell you what your eyes and brains prefer...you can disable and enable BR with a button on the s-switch, so why not experiment for yourself?
BlackJesus
Post by BlackJesus » 21 Dec 2014, 23:50
is there a was to make it brighter on motion blur reduction mode
kimpaul
Post by kimpaul » 17 Feb 2015, 17:39
Its all preferences
