[Help] New 144hz monitor benq xl2411z stutter and lag
frenzy
Post by frenzy » 31 Dec 2014, 17:11
I just received a new benq xl2411z and the exact opposite of what I expected arrived to me. I'm currently running 3 monitors two of which are 60hz on a GTX670. Games stutter moving tabs/programs around skip and even typing this thread the letters show up very slowly and behind what I'm actually typing. Is there any fix to this?
VarHyid
Re: [Help] New 144hz monitor benq xl2411z stutter and lag
Post by VarHyid » 27 Jan 2015, 18:22
- Do all screens run at the same resolution and same refresh rate?
- Did you try to use different input methods to exclude the possibility that anything connected to one specific input will stutter?
- Does the issue persist if you try to set up all 3 screens to "clone" mode so that they all display the same stuff and if it does, does selecting a different clone source make any difference?
matthewdg1973
Post by matthewdg1973 » 28 Jan 2015, 07:57
I had this same problem when I had my XL2420Z connected at the same time as my 60Hz monitor. Once I disconnected the 60Hz monitor the utility was very useful and my XL2420Z works flawlessly now. Don't really know if mix matching monitors with different refresh rates i.e. 144Hz with a 60Hz is ideal or maybe both need to be at the same refresh. Sorry I'm still a bit new to this and only giving what I know at this time. Hopefully it helps.
~Intel i7-3770 3.4GHz~CM Hyper 212 EVO~Gigabyte GA-Z77MX-D3H~EVGA GTX 970 SSC+~Corsair Vengeance LP 16GB DDR3 1600~Corsair Performance Pro 256GB SSD~WD Black 1TB 7200RPM~Seasonic SS-760XP2 80 Plus Plat~Silverstone Temjin TJ08B-E~BenQ XL2420Z 1920x1080 (3)
